<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.057]]></title><description><![CDATA[<h3>VectorStyler 1.0.057 release notes</h3>
<li>Improved: option to set grid count (instead of spacing), line grid, wave shapes.</li>
<li>Fixed: excluding grid shape from text shape should handle grouping.</li>
<li>Fixed: excluding open from open path should create separate sub paths.</li>
<li>Fixed: separating paths with small overlaps.</li>
<li>Fixed: brush content transformation did not work.</li>
<li>Fixed: do not remove shape when shape options of a tool are edited.</li>
<li>Fixed: new path brush paint did not refresh correctly.</li>
<li>Fixed: painting with path brush inside a shape should not remove the shape.</li>
<li>Fixed: time display in document info panel.</li>
<li>Fixed: swap fill and stroke style in color panel when no object is selected.</li>
<li>Fixed: text underline with multiple character overrides did not render correctly.</li>
<li>Fixed: editing concentric warp shapes.</li>
<li>Fixed: grid opacity (and other options) should be kept for new documents.</li>
<li>Fixed: opening or importing AI files with monochrome mask images should result in the same VS.</li>
<li>Fixed: offset path to auto close path with overlapping start / end nodes.</li>
<li>Fixed: some halftone image effect point shapes have wrong thresholds.</li>
<li>Fixed: alignment mode should be persistent between selections.</li>
<li>Fixed: moving popover panels from title background resulted in an empty view.</li>
<li>Fixed: ignore partial names in number field metric resolution.</li>
<li>Fixed: blending steps to be global and used in blend editor to create new blend effects.</li>
<li>Fixed: clipped gradient in CMYK mode was not visible.</li>
<li>Fixed: some clipping groups were not positioned correctly.</li>
<li>Fixed: path node type was wrong in AI import.</li>
<li>Fixed: double and triple flag warp tools are not working.</li>
<li>Fixed: default width of underline should be thinner.</li>
<li>Fixed: shape editor did not update on selection change.</li>
<li>Fixed: keep a preset selection after removing preset.</li>
<li>Fixed: renaming presets did not save the preset automatically.</li>
<li>Fixed: improve offset path node count and precision.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/947/update-1-0-057</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:29 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/947.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Oct 2021 17:32:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.057 on Mon, 18 Oct 2021 20:46:58 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Thank you for all the fixes and updates. VS gets better every week.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/4631</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/4631</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 18 Oct 2021 20:46:58 GMT</pubDate></item></channel></rss>
