<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 155]]></title><description><![CDATA[<h3>VectorStyler beta 155 release notes</h3>
<li>Improved: added OpenType-SVG color font support.</li>
<li>Improved: blend tool uses mouse press + dragging to select first and second object for blending.</li>
<li>Improved: blend tool previews the created blend while dragging the mouse.</li>
<li>Improved: glyph panel selection persistence.</li>
<li>Fixed: regression in shape node editor caused editing to be broken.</li>
<li>Fixed: glyph frame editing cursor was wrong (accessed from glyph panel menu).</li>
<li>Fixed: inline symbols in text shapes caused crashes.</li>
<li>Fixed: problems in complex shape filter hierarchy may.</li>
<li>Fixed: initial export file names should mirror document name.</li>
<li>Fixed: importing and rendering some layer blend modes from AI files.</li>
<li>Fixed: stroke was broken at cusp corners with zero handles.</li>
<li>Fixed: shortcut handling with other input methods.</li>
<li>Fixed: improved input methods for other languages.</li>
<li>Fixed: diacritics input using option+.</li>
<li>Fixed: error in Unicode casing of the letter J.</li>
<li>Fixed: blending shapes with smooth nodes.</li>
<li>Fixed: break apart may move some imported shapes.</li>
<li>Fixed: copy PDF to clipboard.</li>
<li>Fixed: document naming for new documents may reuse old name.</li>
<li>Fixed: curve smoothness in some shape effects.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/98/build-155</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:50:25 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/98.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Aug 2020 19:53:05 GMT</pubDate><ttl>60</ttl></channel></rss>
