<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.061]]></title><description><![CDATA[<h3>VectorStyler 1.0.061 release notes</h3>
<li>Improved: select all on sub-path only if a node or location of that sub-path is already selected.</li>
<li>Improved: option to always paste paste at the current artboard center.</li>
<li>Improved: capital height option when aligning a text on path.</li>
<li>Fixed: exporting fonts to PDF and Postscript format.</li>
<li>Fixed: storing resolution into JPEG files.</li>
<li>Fixed: regression when merging shapes.</li>
<li>Fixed: ligatures of certain OpenType font did not work.</li>
<li>Fixed: problems with registration color tint slider.</li>
<li>Fixed: count sliders for grid shapes to have correct limits.</li>
<li>Fixed: merge should auto close open paths.</li>
<li>Fixed: distribute nodes along a line from the alignment panel.</li>
<li>Fixed: possible crash when dragging a color into a color group.</li>
<li>Fixed: allow single path union and merge to remove self overlaps.</li>
<li>Fixed: open documents not reopening when restarting.</li>
<li>Fixed: spell checker did not correctly highlight words.</li>
<li>Fixed: stroke may break with almost overlapping nodes.</li>
<li>Fixed: shortcut T did not activate the actual horizontal text tool.</li>
<li>Fixed: typing text should refresh faster.</li>
<li>Fixed: alignment panel options were not persistent.</li>
<li>Fixed: working with multiple palettes saved separately from the document.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/987/update-1-0-061</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:12 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/987.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Oct 2021 19:39:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.061 on Fri, 29 Oct 2021 21:47:17 GMT]]></title><description><![CDATA[<p dir="auto">Regression in 1.0.060 did not handle the arrow key shortcuts. This is fixed in 1.0.061.<br />
But for now, the numeric keypad shortcut handling remains open.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/4836</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/4836</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 29 Oct 2021 21:47:17 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.0.061 on Fri, 29 Oct 2021 20:37:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> If nothing is selected, then Cmd+A should select all nodes (not just one sub-path).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/4835</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/4835</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 29 Oct 2021 20:37:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.0.061 on Fri, 29 Oct 2021 20:12:07 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/4833">update 1.0.060</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">This is nice, but would it be a problem if pressing Cmd-A a second time would select all nodes of all paths of the object?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/4834</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/4834</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Fri, 29 Oct 2021 20:12:07 GMT</pubDate></item></channel></rss>
