update 1.1.028
@vectoradmin said in update 1.1.028:
Unexpected and unwanted color mode changes.
Great - so many fixes - this one wasn't solved though:
Unexpected and unwanted color mode changesFrom .28:
Pen tool did not draw when Above insertion mode was selected.
Now draws but on top of everything:
MovieAnd sometimes doesn't draw still. You forgot to include some of these fixes in the build?
Control + backspace deactivated object name editor in Layers panel on MacOS.
Still does?? (Unless the object name is an active selection)
@vectoradmin Thank you for another awesome build update! I appreciate it
@vectoradmin It was so encouraging to see all the fixes you implemented. Thank you for doing such an excellent job, it is much appreciated!
Thursday late evening I proposed a new feature to @vectoradmin and now it's already in the build! Amazing. You can now interactively edit a transform shape effect. This needs to be enable by Preferences > Panels > Transform Effect Editing.
Overly specific guide for clarity. The various restrictions I describe don't really exist, but are for the clarity of instruction:
- create a red rectangle at the top layer
- open the "Panels" application menu
- open the "Effects" sub menu
- select "Shape Effects"
- click on the "+" button at the bottom of the panel
- select "Outline > Transform", the shape effect appears
- unfold the shape effect by clicking on the arrow to the left of it
- enable interactive editing by clicking on the "pencil on a square" icon at the bottom of the panel
- move the object a bit ( this is needed atm, I suspect due to some internal mechanism I discussed with @vectoradmin via email )
- now apply any transformation via the transform tool and see the changes appear in the various fields of the panel
@Nils @vectoradmin This is awesome!
Having this much feedback and control over the effect is really valuable for getting the results one desires, and stacking the effects non-destructively is so powerful, just like modifier stacks in 3D software. I found my new toy within VectorStyler! I will be playing with this a lot in the next while.
Thank you both! -
@Nils Thanks for suggesting this to @vectoradmin and for alerting us to the details of how to get it to work so we can enjoy it
Stroke style role on solid stroke did not work.
Nice to have this one fixed! So nice to be able to use the solid stroke properly and not have it convert to another brush each time.
@Ingolf said in update 1.1.028:
Looks like a some cases were not tested properly. I keep these issues open.
Here it only deactivates after everything was deleted and was pressed again on an empty field. Is that the case?
The fix is in, but it looks like only partial. When clicking with the pen tool on an existing object it will change the selection and that causes to draw on top of that object (this will be fixed).
I could not replicate the the case when it is not drawing.
I described my findings here to move it to the appropriate section of the forum
https://vectorstyler.com/forum/topic/1843/draw-above-bugI could not replicate the the case when it is not drawing.
I will try to establish a pattern. I experienced it once, I believe the issue was somewhat mitigated in build 28, at least.
I see two weird behaviors:
A) Deactivated cursor
- Object name Vector
- No active selection in field
- Place cursor behind the letter r
- Press Control + backspace
- Input field is now blank
- Cursor not active and nothing happens when typing something
B) Leftover letter
- Object name {Path}
- Place cursor behind the char }
- Cursor blinking in the beginning of the input field
- ... in front of a surviving { char
Looks like a some cases were not tested properly. I keep these issues open.Nailed this down as well
Below a discovery that may point to a possible root cause:It always happens when I create an object with the pen tool and swap fill and outline styles (Shift+X) which is what I always do after drawing an object. That is why it bothers me so much and often.
Steps to reproduce
- Enable keep color mode and HSB mode
- New document
- Activate pen tool (fill is now empty, stroke is black)
- Draw a simple closed shape
- Swap swap fill and outline styles (HSB still active color mode)
- Click on fill to bring it on top
- RGB is now active color mode
Observation that perhaps points to a root cause
- New document
- Make a single tiny adjustment to the stroke color (ie +1 in saturation)
- HSB is still active color mode
- Looks like RGB is carried over from the stroke color initially (although HSB or something else is displayed) unless I make an adjustment?
@Ingolf All 3 non-fixed problems can be replicated.
@vectoradmin, thanks for all the fixes and i found one thing is working now:
"Select and move multiple node handles". Great
Video:
Multiple Handles selection
@vectoradmin Is this about the app not reading the embedded fonts in a PDF on import?
- Disable automatic scanning of fonts from PDF files.
@b77 said in update 1.1.028:
No. It is about the font manager. The VS font manager can scan PDF (and PS) files as fonts, if they have embedded fonts.
It does not affect the import.
