    update 1.1.044
    38 Posts 7 Posters 13.9k Views 6 Watching
      @VectorStyler Originally I mentioned this hide/unhide pivot point because it is visual noise for as long as I don't need it AND I activated it by accident too many times. Both when objects were small and not. But I use it occasionally. No algorithms can predict when I feel like rotating something with an adjusted pivot point. But I don't need to look at something when I don't plan to use it. I imagine those have been the arguments in Nottingham for their choice.
      Now that I can hide it and enjoy my drawings with less visual noise I realized the pivot point and the blue point that marks the center of the object/selection are of course closely related. Apologies. πŸ˜•
      I suggest that when the pivot point is hidden in the context panel, the blue center point is hidden as well.
      To mention Affinity again, they chose a simple solution where this pivot point simply appears when I drag my rotation point around. It makes sense, because what matters now is which pivot point is actually selected. And then there is less visual noise, and no doubt about which point the object is actually rotated around. But that's another matter that doesn't bother me so much. Just had to mention it:
      alt text
      It's possible not everyone understands it, but for some it's wonderful and an incredible help to focus on the design that all sorts of lines and circles and colors aren't visible on top of the graphics when it's not being used right at that moment!
      And bingo - there you have the reason for all the praise Affinity has received for their easy-to-use applications, because they actually did a lot of things right - from the customers' point of view - when they designed the applications' basic functionality from scratch.
        b77 @Ingolf
        @Ingolf A few versions ago the developer improved canvas panning so that when you press the spacebar, all the visual noise (bounding boxes, pivots, center indicators) are hidden. It became a reflex for me to press the spacebar.
          @b77 I did not notice that! I'm glad you mentioned it because it will become part of my workflow for sure. Great subtle addition to VS. Those are probably things that were listed in the new build notes that I was unable to follow and needed more explanation on
            Affinity has many fewer options to begin with, so even adding those into the contextual menu for them, does not make the program UI seem too complicated and busy (yet).
            The preferences eventually are going to have to be labeled/organized better (easier said than done I know) and there may need to be some way to find the right setting by reverse searching in the documentation - looking under a certain topic like the pen tool and seeing what settings in preferences are applicable to that, etc. This may take a while since @VectorStyler is taking the next couple years to add new features and rework things.
            Perhaps these options @Ingolf advocates for could be moved to being an option in the eventual custom contextual menu section down the road? - because I don't see these as being typical regular user requirements to be so accessible
              VectorStyler @Jayanta Das
              @Jayanta-Das said in update 1.1.044:
              I face some issues with center rotate pivot.
              What I did-
              1. Create two rectangle side by side and select both.
              2. Move the center pivot somewhere and rotate.
              3. Now select one rectangle and try to place its pivot to the center of the rectangle.
                The pivot doesn't stay at the center of the rectangle.
              Tried to replicate the pivot movement issue, but here it seems to be working: https://recordit.co/GvEQoCg7KR
                VectorStyler @Ingolf
                @Ingolf @b77 @Boldline I think the customization of the context bar (planned for the future) will solve some of these issues.
                • J Offline
                  Jayanta Das @VectorStyler
                  @VectorStyler said in update 1.1.044:
                  • Right click should not remove selection.
                  The issue is still there.
                  Mac Mini M4 Pro | 24Gb
                  WIndows 11 | Intel i5 11Gen
                  Wacom Intuos Pro
                    Could not replicate this.
                    • J Offline
                      @VectorStyler Just tried it again, it has issue in right click
                      Wacom Intuos Pro
                        @Jayanta-Das Can you send me a screenshot of the toolbox. It might depend on some active tool.
                        • J Offline
                          @VectorStyler Here it is.
                          Wacom Intuos Pro
                            @Jayanta-Das I tried to replicate the right click deselect issue it on Windows but it seems to be working here.
                            The next thing to try is a reset: start the app while holding contor+alt+shift
                            J S 2 Replies Last reply Reply Quote 0
                            • J Offline
                              @VectorStyler I did reset as you said but the issue is still there.
                              Wacom Intuos Pro
                                Subpath @VectorStyler
                                seems a typo ?
                                color... is maybe Control ?
                                • J Offline
                                  Jayanta Das @Subpath
                                  @Subpath Yes it is.
                                  Wacom Intuos Pro
