    Was the shortcut to click on a file name tab to see it file location removed?
    9 Posts 4 Posters 8.2k Views 3 Watching
      I remember a while back we discussed adding the option to find the source location of an opened file in VS by clicking on the file name tab with a modifier key and it would show the file in it's location. I know that got added because I frequently used it. Was that removed?
        @Boldline On Mac: Option+ click on the document title tab.
          @VectorStyler ok I had initially tried that without success. Then later VS crashed and now that it's open again, the Option+ click works again. thanks
          UPDATE: Does this feature only work with native VS files? Because I can successfully do that with VS files, but an Illustrator file will not work
            @Boldline It is not working with AI files. Will fix that.
              @VectorStyler It does not seem to work for eps or pdf files either....
              • F Online
                fde101 Global Moderator
                Why option instead of command, which is the standard key for doing that?
                  VectorStyler @fde101
                  @fde101 said in Was the shortcut to click on a file name tab to see it file location removed?:
                  I will verify if it is in conflict with something else, and change it to Command if not.
                  Also: it will be configurable.
                  • J Offline
                    Jayanta Das @VectorStyler
                    @VectorStyler I tried it but I could not see the file location.
                    Mac Mini M4 Pro | 24Gb
                    WIndows 11 | Intel i5 11Gen
                    Wacom Intuos Pro
                      VectorStyler @Jayanta Das
                      @Jayanta-Das I check what happens on Windows. Normally, it should open the file Explorer and highlight the file.
