    3 questions: font selector, scaling, control nodes
    10 Posts 4 Posters 8.9k Views 4 Watching
    • ? Offline
      A Former User
      Hi, I have 3 questions:
      1. Can I fix the font preview size in that selector?
      1. Is proportional scaling, anchored to an opposite edge, available? I mean I drag the bottom to scale proportionally while the upper edge stays in place?
        Dragging midpoints doesn't do that or is there a setting for it?
      2. Can shape control node colors be changed? Like those scaling ones etc.
        b77 @Guest
        (1) The first issue (font preview) seems to be a Windows-only issue. Here it is properly centered.
        (2) When dragging by a corner of the bounding box, press Shift to preserve the aspect ratio.
        If you want, you can enable 'Proportional Object Scaling' in Prefs > Editing Options 2, so you don't need to press Shift for that.
        (3) You can change the node colors in Prefs > Editing Options 1 — you need to choose the node type from the second dropdown menu there.
          Subpath @b77
          slight addition to Point 2:
          ... enable 'Proportional Object Scaling' in Prefs > Editing Options 2...
          after you enable that, you still need to press the Shift-Key when:
          -- you create a Rectangle or a Circle, once created you doesnt need it
          -- if you scale a single Textline "Shape Text" after you have create it
          • ? Offline
            A Former User
            1. It may be a Windows issue, but it's impossible to determine the font 😕
            2. Proportional scaling moves all the edges in/outside. I need to drag the bottom one and scale proportionally to NOT MOVE the upper one, to keep the upper distance to another object.
            3. I tried that option before, but the list has SO MANY entries that I thought it's impossible that it's the one I need.
              There should be a single (or an additional) option to get all the controls colors set at once. Anyway, it finally looks as it should.
            Thanks!
              VectorStyler @Guest
              @plrang said in 3 questions: font selector, scaling, control nodes:
              There seems to be no option to control this, and from the screenshot looks like a bug.
              I added this to the list of bugs, will be fixed ASAP.
                VectorStyler @Guest
                this is not clear for me, do you have an example, maybe a short recording ? (we use https://recordit.co/ for screen recordings).
                EDIT: fixed the https://recordit.co/ link
                • ? Offline
                  A Former User @VectorStyler
                  @VectorStyler SURE, btw. that link is wrong.
                  I'm resizing dragging the bottom edge to keep the distance.
                  I think the current scaling options in VectorStyler don't allow me to do it?
                    b77 @Guest
                    @VectorStyler Maybe Ctrl-Shift could be used for this.
                      VectorStyler @Guest
                      @plrang @b77 Got it! Looks like a feature that is missing. Shift+ should work when dragging from the side also, added to the backlog.
                      • ? Offline
                        @VectorStyler Amazing, Affinity uses just the SHIFT.
