    Should we add the "convert to curves" shortcut icon to the contextual menu bar associated with the node editing tool?
    2 Posts 2 Posters 3.2k Views 1 Watching
      Would it make sense to add the "convert to curves" shortcut icon to the contextual menu bar associated with the node editing tool?
      I've often found myself using the node editing tool to select shapes and then went to look for the icon and it was not there - finally I realized it was only there when the transform tool was selected.
      I'm not saying it has to be there - I don't want to clog things up
        @Boldline I think it could be there. What happens is that when a parametric (rectangle, ellipse, ...) shape is selected with the node tool, its properties should be editable from the context panel, and among those properties, there si also a button to convert.
