    Does this program work with Mojave?
    29 Posts 4 Posters 37.6k Views 4 Watching
    • J Offline
      jfraze @Subpath
      @Subpath Thanks. I know how to create text on a path. That part is working fine. The problem here is selecting the path with its text so I can move it into position... and the mysterious way in which this particular object sits behind the jpeg background no matter what I do. See in the video how it disappears behind the background when I move it. It's supposedly in the very top layer, the background is in the very bottom layer, yet this text object appears (or rather disappears) as if behind it.
      Selecting the path with its text is working fine in other objects, but not here. If this was the only time that's happened I'd just delete and start over, but this happens to me frequently enough I'd like to know what's going on.
        VectorStyler @jfraze
        @jfraze said in Does this program work with Mojave?:
        Can you send me by email the example where this is not working. It could be a bug, that we cannot replicate.
        • J Offline
          jfraze @VectorStyler
          @VectorStyler It's 130 MB. I'll see if I can make a reduced-size version that has these issues, but I'll have to work on that later. Thanks for your help. I'm mystified as to why I'm having so many bizarre issues.
            Subpath @jfraze
            @jfraze
            your welcome
            • J Offline
              jfraze @Subpath
              I still haven't had a chance to work on the reduced-size version of the file, but maybe a quick question will help with this... What is the trick for selecting a path with its text? It seems I can only select the path itself, or the text on the path. I can't duplicate or copy/paste the path with the text included. Is there a tool or key combo that would select the whole thing so I could duplicate both at once?
                b77 @jfraze
                @jfraze Click and drag to select the text-on-path object, then Option-drag to duplicate it.
                You can also select the path with click and the text with Shift-click, or vice versa.
                • J Offline
                  jfraze @b77
                  @b77 Click and drag selects everything else around it, too. I want to be able to just select the path with its text, as you can in AI simply by using the direct select tool.
                  Option drag of course duplicates it, but only either the text or the path, whichever I've managed to select. And the duplicate is always ending up mysteriously displaying as if behind my bottom layer, even though the layers palette shows it above everything else.
                  Also, shift click is doing absolutely nothing for me. It doesn't change the selection at all.
                  FYI, I've been using Illustrator (and before that Freehand) professionally for decades, so I do know how to use a vector design program, and how to put together and work with a multilayer vector document. Maybe I should just uninstall this program and re-install from scratch. The descriptions of how things are supposed to work all make perfect sense. But nothing seems to work as it's supposed to for me at all.
                  VectorStylerV b77B 2 Replies Last reply Reply Quote 0
                    They should be selectable as individual objects, or as two objects (Shift+Click) or Box marque.
                    If none of this works, try in the Layers panel by clicking (Shift+) on the small circles at the end of each object.
                      Shift+click works here.
                        b77 @jfraze
                        @jfraze Reinstalling is not needed, as you can reset the app to default by holding down Command-Shift-Option when starting the app.
                        But don't do this before sending the Prefs files to the developer, just in case it's something related to some setting there:
                        • switch to the Finder;
                        • click the 'Go' menu > Go to Folder…
                        • paste this: ~/Library/Application Support/NumericPath/VectorStyler1.0/vector/data/resources
                        • press Enter/Return.
                        • copy these two files (settings.xml and workspace.xml) somewhere else.
                        Then you can reset the app and see if the issue is solved.
                        If it's solved, send the .xml files to the developer's email (csraba at this domain).
                        J 2 Replies Last reply Reply Quote 1
                        • J Offline
                          @VectorStyler Thanks. Yes, I'd discovered the layers panel method right after posting, but marquee select isn't practical since it selects everything around it as well, and shift-click isn't working in my installation.
                          • J Offline
                            jfraze @b77
                            Found a Preference option for "Select Text on Path Anchor." That seems to make it do what I want.
                            Weirdly, it also allows me to duplicate the selected object so that it appears in its correct place in the hierarchy, although I'm not sure why it has that effect. If I marquee select, it always duplicates or copy/pastes into that weird state where it sits in the top layer but is (dis)appearing at the bottom of everything.
                            • J Offline
                              jfraze @b77
                              @b77 Tried that. Now I can import jpegs without them turning into black boxes, so that's an improvement! I'm still not finding that shift-select is doing anything. Is this supposed to be with the Transform Tool or something else?
                                b77 @jfraze
                                @jfraze Yes, Shift-click with the Select/Transfom tool (shortcut: V) works here. I hope you sent the .xml files to the developer.
                                The 'Select Text on Path Anchor' option indeed selects the text and its path, but then you always need to use the special 'Text on Path' tool to select and move just the text along the path — you can't do it with the Select/Transform tool.
                                Were the JPEGs imported into an RGB or CMYK document before app reset?
                                The document's color mode is set in Document Setup (File menu > Document Setup > Color tab).
                                Also: are the imported JPEGs in RGB or CMYK color mode?
                                You can check this from the Finder > right-click the JPEG file > Get Info > Color Space: RGB / CMYK?
                                  b77 @jfraze
                                  @jfraze Is the selection issue happening with a mouse/trackpad or a stylus?
                                  • J Offline
                                    jfraze @b77
                                    Selecting with a mouse and full-size keyboard.
                                    There are no jpegs in the problem document. That was an earlier issue I'd reported. Some were grayscale, some were CMYK, some were RGB. None worked. I could only import eps files prior to the reset. Now it seems jpegs work as they ought, so I might be able to re-do the current problem file with a jpeg and see if that makes it small enough to email. Maybe some other issues are fixed as well. I'll keep an eye out.
                                    At any rate, the reset did not fix the selection issue, or the layer display issue, but using the "text on Path Anchor" option has made all those issues disappear. No idea why but good riddance!
                                    Everyone's been extremely helpful and I appreciate it.
