    Ungrouping changing the appearance of artwork
    12 Posts 6 Posters 9.7k Views 5 Watching
      Subpath @tudor
      @tudor
      I downloaded your file, opened it in VS and exported it as PDF.
      And then loaded that PDF into Coreldraw and Affinity Designer and ungrouped it, both worked
      But the curious thing is, I loaded the PDF exported from VS
      into VS as a test as well and then it works with ungrouping
      The VS file did not work with ungrouping.
      Win 10, VS 1.1.058
      • W Online
        William Kansepa @tudor
        @tudor Can you also attach the original Illustrator file?
        W T 2 Replies Last reply Reply Quote 0
        • W Online
          William Kansepa @William Kansepa
          Sorry if my assumption of it being an Illustrator file is wrong...
            b77 @William Kansepa
            @William-Kansepa It's probably exported from a CAD app.
              VectorStyler @tudor
              @tudor The drawing contains groups using shape combine operations. These can be selected after 3 or 4 ungrouping steps.
              Use Styles -> Expand Group first and then ungroup all.
              How many Ungroup steps were used in Illustrator?
              Ungrouping groups with shape combine operations will have similar results in other apps (where this feature is available).
              One thing that I could do here is to stop Ungroup All at groups having combine operators. I added this to the backlog.
              I also tried the PDF export and then import thing. And since exporting to PDF flattens the shape combine operations, the ungroup all worked as expected after importing.
              T 1 Reply Last reply Reply Quote 0
                Undoing the ungroup crashes VS on macOS. First time I tried I got a never ending spinner (using control-z), second time using toolbar the undo button stays depressed and I have to restart VS.
                  No, second time it came to life again.
                    VectorStyler @Ingolf
                    @Ingolf said in Ungrouping changing the appearance of artwork:
                    Replicated here also.
                    • T Offline
                      tudor @William Kansepa
                      @William-Kansepa said in Ungrouping changing the appearance of artwork:
                      The original was an EPS file downloaded from Getty Images. Here is a sample:
                      https://www.dropbox.com/s/sr82epasubd7m0z/sample.ai?dl=0
                      • T Offline
                        tudor @VectorStyler
                        @VectorStyler said in Ungrouping changing the appearance of artwork:
                        So VS treats a "compound shape" (as Illustrator calls it) like a group. That explains it. It is unusual though, because all other applications I use have different commands for breaking apart compound shapes.
                          VectorStyler @tudor
                          @tudor Yes the Illustrator compound shapes are imported as groups (in the AI file format, they are groups).
