    Something weird is going on with the Stroke
    9 Posts 3 Posters 7.6k Views 3 Watching
    • K Offline
      KT
      I have been trying to set a stroke to a certain object (a curve that I made in & copied from Affinity Designer) and the stroke gets bigger when I try to make it smaller. It will not resize to the stroke I set. See video.
      https://recordit.co/V26QBS9jBm
      I checked settings in the Stroke Panel and Relative Shift was checked so I tried unchecking that but it didn't seem to make any difference. In Preferences I do not have any type of proportional scaling checked.
      Another question...whenever I copy something made in AD on the same Artboard & resolution sizes, it always copies with a smaller stroke and smaller object in general. The same thing happens if I copy some from VS into AD. Does this happen to anyone else and is there a way or setting to adjust it? (I am referring to direct copy & paste, but have had the same issues even with exported svgs.)
      Thanks for any help or suggestions.
      I have copied and pasted many objects from AD in the past and have never had this stroke issue before.
      I am using on older iMac 27" running High Sierrra.
        VectorStyler @KT
        @KT
        I think this could be caused by some transform on the shape or stroke. If you could send me by email an example, I will try to replicate it.
        I checked this using the Transform panel in both apps, and it seems that I cannot replicate it here. Again it might be some specific example that ends up with an extra transform
        K 1 Reply Last reply Reply Quote 1
          Subpath @KT
          @KT
          see only a resizing if i copy and past from
          VS into AD
          if i copy and past from AD to VS
          i dont regonize any change
          with SVG, PDF Export from VS and Import in AD
            @KT
            Btw did you know the Style Picker in VS ?
            It could be helpful to set the Stroke With
            and Styles in general between Objects
            Here a Video of some uses
            • K Offline
              KT @VectorStyler
              @VectorStyler Ok, thanks. I will send the file.
              • K Offline
                KT @Subpath
                @Subpath Thanks so much for testing that. Any ideas about why it resizes from copy and paste between the programs?
                I just tested another svg export from AD into VS and it was fine. I'll have to watch for that happening again, it opened fine in VS today.
                I appreciate the video. I occasionally use the Style Picker for color but forget it does much more. Thanks--that will be very useful! 🙂
                  Subpath @KT
                  @KT said in Something weird is going on with the Stroke:
                  Sorry not really, but i guess some File conversion Probs.
                  That one Program interpret the File Format a bit different
                  or has Bugs.
                  you could only try different File Formats and use
                  the one which works best
                    Subpath @KT
                    Indeed. And dont forget to try the Shape Picker e.g .... 🙂
                    One additional Tip. If you use any of this Picker you
                    could press and hold the Ctrl-Key to bring temporally
                    the Transform Tool up.
                    ( i think Ctrl is the Command key on Mac)
                    This way you could select objects faster without
                    switching the tool.
                    Short Video about that here
                    • K Offline
                      KT @Subpath
                      @Subpath said in Something weird is going on with the Stroke:
                      Nice! I didn't know about that tip--thanks! 🙂
