    Drop shadow offset
    7 Posts 3 Posters 6.1k Views 3 Watching
      Suddenly realized we desperately need a shadow offset slider in image effects. Or is it hidden somewhere?
      Shadow offset
        b77 @Ingolf
        @Ingolf Probably not the best name, but the Size slider does that.
          Ingolf @b77
          @b77 said in Drop shadow offset:
          Thanks. Yes, offset is not my favorite either so I looked in Photoshop:
            @VectorStyler BTW when I add a drop shadow effect the color is black but transparent in the image effect settings. If I click it the color is changed to white.
              The effect of the adjustments should be updated "live" while adjusting the sliders. It is more like throwing darts now.
                b77 @Ingolf
                @Ingolf When changing the values of the effect from the 'Image Effects' panel (Panels > Effects > Image Effects), the adjustments are updated live.
                But indeed, it doesn't work like that when sliders are adjusted from the window that shows the effect. Is it because it's a modal window, @VectorStyler?
                @Ingolf Btw, you can also click the pencil button at the bottom of the 'Image Effects' panel to adjust the values directly on the object.
                  VectorStyler @Ingolf
                  @Ingolf said in Drop shadow offset:
                  Will fix this.
