    Sometimes live preview is not handy lol
    19 Posts 4 Posters 19.1k Views 3 Watching
      Boldline @Subpath
      @Subpath said in Sometimes live preview is not handy lol:
      I'm not sure if a delay would be helpful and how long it should be.
      And it finally does not solve the problem with a lot of objects.
      I agree that nothing will solve the delay when dealing with a large selection of objects. I'm more talking about avoid the needless previews when you are scrolling down a list of actions to find the right one and the cursor triggers a preview of a complicated task - combine that with a complex art file and you sit there waiting needlessly for 2-4 minutes while it processes.
      I'm not talking as much about the boolean operations - more like the things listed in the object>shape submenu for example
      0_1667931222637_608372e9-0ce1-4845-b5d1-e033df532993-BLD 2022-11-08 at 13.13.26.png
      I was thinking a short delay, long enough to move the cursor down a list of actions without triggering them until you get to the one you want would help avoid needless preview actions from slowing things down. i don't know what it's set to now by default, but maybe increase it a little and see if that allows for unimpeded scrolling of items in a list?
        b77
        As suggested by @Subpath, limiting the preview to work only under an object count limit would be best IMO.
          @b77 said in Sometimes live preview is not handy lol:
          I don't understand what that means, to be honest . are you saying a limited number of items would be affected initially by the preview?
            @Boldline Sorry, reformulating:
            Preview could work for a limited number of objects. Not just three or four, but not 24 either, I guess.
              @b77 ok, I think that could be a good solution as it allows for previewing and it helps me with larger projects not getting slowed down for previews I didn't want - my only concern with @Subpath 's idea is that it looks right when partially done. Right now for example, with the selection box, there are a limited number of nodes that get selected and light up - sometimes that causes me confusion in knowing what is truly selected - sometimes it's a large patch of lit up nodes and nothing else in the rest of the selection lol. I know @vectorstyler had improvements for that in the queue
                The node highlight limit is 500, meaning when you hover an object with under 500 nodes
                (and 'Show Nodes when Hovering' is enabled in Prefs > Editing Options 2) you will see
                its nodes and if they are more than 500 you won't — they are not highlighted.
                Similar to this, the node count could be used instead of object count for limiting
                the previewing of these operations you mention.
                  @b77 - I'm not against it if @VectorStyler can pull it off. I can potentially see it going well. I just also see potential for a lot of confusion when part of a design is edited by the action preview and the rest is not.
                    @Boldline Previewing would be off for all selected shapes, not just for some.
                    Otherwise it would be confusing indeed. 😅
                      @b77 I'm pretty lost at this point on what this solution will look like - so I'll just see what @VectorStyler figures out in due time
                        @Boldline It would look just like when 'Preview Shape Combine' is disabled in
                        Prefs > Document Editor — no preview of Booleans or other operation.
                          @b77 has already explained it correctly what i meant.
                          Of course, it would be nice if you could specify the number of objects from
                          which no live preview would be displayed.
                          One thing that came to my mind about the delay solution was that with this solution
                          would affect every boolean operation. No matter how many objects are used for it.
                          I also see the possibility to link the delay to the number of objects.
