How to see long names for selected images
Is there a way to see the full name of the selected image in the document? If I select an imported image and look to the contextual menu bar, the name, if too long, gets cut off. there does not seem to be an easy way to see the full name - I tried hovering over it, clicking on it, etc...
@Boldline There is limited room for this in the Context panel.
Details on linked images can be seen in the Links panel, when hovering over the image in the list. -
@VectorStyler The full name could be shown in a tooltip when you hover the selection info area in the context panel.
@b77 said in How to see long names for selected images:
@VectorStyler Yes this was what I was thinking could be a good solution. I'll also make more use of the links panel
Would it make sense to also let a double click of the name area in the contextual menu open the links panel? Much like the vertical tool bar options can be double clicked and it opens the appropriate panel?
Added this to the backlog.
