    update 1.1.077
    3 Posts 2 Posters 792 Views 1 Watching
      VectorStyler 1.1.077 release notes
      • Fixed regression in the missing font warning of certain font kinds.
      • Importing bw bitmap should create mask images.
      • Add image mask option to image content type.
      • Importing masked bw images from AI format.
      • Artboard coordinates of objects inside transformed groups.
      • Deleting nodes between certain collinear lines should create the correct connection.
      • Fixed regression in bristle brush shape editing.
      • Fixed crash when exporting to PDF with JPEG encoded images.
      • Do not open layer or object options in Layers panel for locked layers or objects.
      • Fixed crash when exporting noise blur effect at large resolution.
      • Fixed crash when linking SVG documents into the drawing.
      • Skewing inside rotated groups to show the correct preview and markers.
      • Deleting multiple nodes to result in correct smooth node handles.
      • Font attribute changes on copied text should not propagate to the copied version.
      • Convert to curves of cloned objects.
      • Pass the actual document file name to the printer.
      • Fixed regression in contour panel step mode and profile selection.
      • Initial content of new objects should be set to opaque.
      • Image effect transparency when used as an adjustment content in an object.
      • Allow drag and drop of actions in the tool box editor.
      • Enable reshaping in pencil tool.
      • Stroke width selection on transformed text to account for the correct stroke transformation.
      • Allow the use of corner styles on the selected corners only.
      • Variable fonts to show correct parameters of the selected font instance.
      • Add warning when trying to change styles that originate from objects with a role.
      • Deleting the content of a number field should leave an empty box.
      • Added preferences option to import or link files when using drag and drop on the document view.
      • Expand Linked Files action should remove the content if not used in other parts of the document.
      • Automatically enable or disable the bleed visibility depending on the bleed settings of a document.
      BoldlineB 1 Reply Last reply Reply Quote 6
        @VectorStyler said in update 1.1.077:
        This is great! I love that it's an option in preferences and that by having it set to embed by default, no one mistakenly loses something because of a missing link assuming it's embedded when it's not, etc. It's a very easy thing to switch over to link by default in preferences now for those who prefer that.
        I assume using the option key gives the opposite result from what has been set as the default in preferences?
          @Boldline said in update 1.1.077:
          Yes, holding Option flips this mode.
