Object counter tool tip not showing in last two builds
When I used build 76, I noticed i was unable to see the object counter that is part of the selection box. Upgraded to build 77 and the problem remains. Is there a setting specifically for that? I'm not referring to the tooltips overall, just the one that shows how many objects are selected currently.
@Boldline It works here both with Prefs > Editing Options 2 > 'Intersecting Selection' enabled and disabled: https://recordit.co/mZxgF8uzui
Thanks for testing it. That's exactly the thing I was talking about. I'm glad for some reason. Glad it works for you - still not working here yet for some reason.
https://recordit.co/j3dQWzbnSG
I restarted VS and also set the preferences back to default and I still can't get it to show the object count. I had "intersecting selection" on and I then also tried with that setting turned off. I still can't get it to show the count of selected items.
If not a preferences issue, would it be a workspace issue? -
@Boldline You can restore the workspace to default (VectorStyler > Workspaces > Restore Default).
@b77 I set the workspace back to the default and the selection counter resumed working properly. I'll send you the workspace file @VectorStyler
