    Copying and pasting path segments
    11 Posts 4 Posters 10.7k Views 3 Watching
      Subpath @William Kansepa
      @William-Kansepa
      if your Path is a closed one, then open it
      and try again
      if i remember right i once find out that
      copy and paste a segment of a Path work
      only on a open Path
      try this way to copy a segement on a open path:
      select your segment
      copy it
      deselect your path
      and paste that segment
      W 1 Reply Last reply Reply Quote 1
      • W Online
        William Kansepa @Subpath
        @Subpath said in Copying and pasting path segments:
        and try again
        Thank you @Subpath and I was actually working on an open path... It's not working.
          @William-Kansepa said in Copying and pasting path segments:
          and try again
          please read my previous comment again
          i extend it a bit
          • W Online
            @Subpath It would make a lot of sense if it would work that way, but it's not...
              its working here this way
              here a video
              W Victor VectorV 2 Replies Last reply Reply Quote 1
              • W Online
                @Subpath thank you so much for the video. Yes, I see it's working 🍻 I probably need to have a look at my settings!
                • Victor VectorV Offline
                  Victor Vector @Subpath
                  @Subpath @William-Kansepa
                  Interesting. For me:
                  1. Draw an open shape with the Pen tool,
                  2. switch to the Shape Editor,
                  3. select a few nodes,
                  4. CTRL +C,
                  5. switch to the Transform Tool,
                  6. deselect the shape,
                  7. CTRL + V.
                  The copied path is available to manipulate.
                  W 1 Reply Last reply Reply Quote 2
                  • W Online
                    William Kansepa @Victor Vector
                    @Victor-Vector said in Copying and pasting path segments:
                    4. CTRL +C,
                    7. CTRL + V.
                    I got it now... phew. I was selecting the segment directly not the nodes. I am so used to the AI method my bad. In AI you can select either the segment or points and it will work.
                    Everything is working as expected now. Thank you @Subpath @Victor-Vector.
                    God I love this forum 🕺🏾🕺🏾
                      @William-Kansepa , @Victor-Vector
                      btw. if you are a bit adventurous like me 🙂
                      something like this is also possible
                      see video here
                        VectorStyler @William Kansepa
                        I am thinking that the Shape Editor Tool exhibits the same traits as the Direct Selection Tool in AI?
                        Similar, yes.
                        And for pasting a copied path section: select a node (preferably an ending node) and the path is pasted as a continuation there.
                        Otherwise, it is pasted as a new object.
