Text Horrors
  • TBH, this is really the first time I've seriously needed to use 'text' in a VS document.
    I have to say that I find it absolutely horrifying, am I the only one that has found this - I feel I'm on a bit of a rant and must be missing something blatantly obvious ???
    Something as simple to use in AI as the Type Tool just doesn't seem to exist in VS. The only 'useable' text tool seems to be the area text tool. Both that and the 'text' tool are completely unselectable at lower zoom levels where I require to push and shove bits of disparate text about to fit on drawings. The 'text' tool texts end up with hundreds of selectable bubbles/nodes around and you can't see anything, using 'frame text' ends up with frames getting resized/rounded or just plain unmovable etc.
    You need to be at such a high zoom level to be able to select the text frame/text block that you can't see where you you are going regarding the rest of the document objects.
    I've had a scrub around the forum, but can't find any others with this issue, so can only assume it's me 🙂 ???
    I'm hoping that there's some way to switch off all the 'stuff' around the actual text that will just allow you to simply move the blocks around ??
    My sincere apologies for the rant 🙂
    Neil
  • @Igull By 'completely unselectable at lower zoom levels' you mean
    you cannot select and move text objects with the Select/Transform
    tool (shortcut: V), or do you mean you cannot enter text editing mode
    by double-clicking the text?
    Also: is this happening in Outline mode (Cmd-Y)?
  • @Igull It might help to see a video of the issue you are having. Text can be a little tricky in any of the vector programs. I was testing in Affinity Designer and it is also looking similar to what VS has with the large "bubble" corners
    0_1685989115585_5abf4cfa-222b-470b-a367-32834dc7ca35-BLD 2023-06-05 at 14.17.18.png
    In VS, there is the "Move" tool which hides all other options for edit and only allows moving to occur. I've used this when I have multiple small objects that I want to rearrange without having to worry about accidentally modifying the selection
    0_1685989193767_088d58fa-389d-4b40-bb1e-391ba9b6942a-BLD 2023-06-05 at 14.19.30.png
  • @b77 said in Text Horrors:
    tool (shortcut: V),
    Correct.
    That's also an issue at lower zoom levels
    Yes.
    @Igull Can you upload or send me a document, saved with the zoom level where the text frame is hard to select?
    In Outline mode, text frames are selected only when clicking on the outline of the frame.
  • @Boldline said in Text Horrors:
    And there is the simple answer ! That certainly cures all the issues I'm currently having and works at any zoom level without issue - thanks ! I wasn't aware of this tool as I have a self-limited tool setup here - there are far too many tools in the VS arsenal that I don't need (unlike my real workshop 🙂 )
    However 🙂 I'm not sure I understand why it is necessary to have yet another tool do the job of the transform tool - it works perfectly in AI without swapping out to another tool ??
    One thing I did notice with the move tool is that you can option-drag to clone another text block - a saving feature.
    The move tool doesn't pick up the text frame as well as the block text from the text tool - you have to be pretty accurate to just get the edge of the frame - it occasionally works by grabbing the internal text, but not always.
    Thanks for that snippet - it's now on my M shortcut key (like most CAD apps curiously 🙂 )
    Neil
  • @Igull Do you need to be in Outline mode when preparing that user manual you mentioned in another thread?
    Only in Outline mode you have this limitation with selecting text objects — see developer's comment.
  • @Igull said in Text Horrors:
    Try checking off these settings in Preferences:
    Editing Options 2:
    Edit Corners in Transform Tool
    Edit Corners on Node Tool
    If you turn these off the aforementioned bubbles won't show.
  • @William-Kansepa said in Text Horrors:
    Doh, I think age must be a hindrance here, I just didn't think to switch those off 🙂 🙂
    Thanks for that, that essentially fixes all the other zoom issues too - and using the transform tool to boot LOL
    Thanks for that and thanks to everyone else for chiming in on the issue ! Text editing is so much easier here now 🙂
    TBH, the only time I ever adjust corner radii is accurately via the panel editfield and never by hand, so those prefs can remain saved.
    Neil
    TBH, the only time I ever adjust corner radii is accurately via the panel edit field and never by hand, so those prefs can remain saved.
    It's interesting because for me I almost always size by visual appearance and rarely by setting a certain number. I'm sure it has a lot to do with how technical our fields are in terms of what is required. Finding options for both types of users is best.
    Yes, absolutely right !
    As an aside, I'm having other issues today with corners 🙂 Resizing a 5mm cornered rectangle screws up the corners - they don't remain the same size - even when sizing proportionately (shift key) and the line thickness gets thicker on the left and right sides of the rectangle also which I can't seem to rectify. Even using a convert to curves on the rectangle to start with still causes the same problems 😞
    Any thoughts/solutions ?
    Edit: Update, drawing any rectangle/oval is having the same issue with line widths. However, I'n finding that if I click the 'stroke inside' then back to 'stroke outside' the path, it resets the width issue - looks like a bug to me, I'll wait before I post the bug for now. Still having the non-symmetrical corner issue though.
    Neil
  • @Igull It would help some to take screenshots and do some screen recording and including those with your questions so others can see what you are dealing with
3 out of 12
