    Distribute objects with value?
    15 Posts 5 Posters 12.0k Views 4 Watching
    • IgullI Offline
      Igull
      Currently, I can only see an object distribution that offers an equal gap between each (distributed between the first and last selection - say).
      Is there any way to set that equality gap to a value - starting at zero (or even a negative value) ? Obviously, it would mean moving perhaps the first or last object out of position in X or Y. It would be the same value between each, not different values - although that might also be an option ???
      Doing it manually is very painful 🙂
      I can't remember which application it was, but you could set an invisible force field around objects to give equidistant spacing when pushing them together (a bit like text wrap around an image in Pagemaker/Quark Express (LOL or whatever DTP software modern folks use in the 21st century - is it even called DTP now 🙂 )
      TIA
      Neil
        Subpath @Igull
        @Igull
        could blend and blend options be helpful ?
        see video here
        • IgullI Offline
          Igull @Subpath
          @Subpath said in Distribute objects with value?:
          That could certainly do the variable distance between objects, I hadn't thought of using blend for that - bit like adjusting exponential curves on my RC aircraft transmitter LOL.
          I do use blend in this manner to create a 'loft' between parts - that works well.
          For a fixed distance, I'm thinking of an added distribute command to the alignment panel that offers equal distance between objects - except that you get a popup asking the distance required - perhaps even use the current one with an editfield in which you simply put the required value in - the default being an = ???
          Just some thoughts, thanks for that.
          Neil
            Subpath @Igull
            @Igull
            ... bit like adjusting exponential curves on my RC aircraft transmitter ...
            yes it is 🙂
              VectorStyler @Igull
              @Igull To space objects at a fixed distance: open the Alignment panel and from the panel menu enable the Alignment Options.
              Select the objects, set a spacing amount in the Space field and use the fourth mode in the Align Position icon row.
              IgullI encartE 2 Replies Last reply Reply Quote 0
              • IgullI Offline
                Igull @VectorStyler
                @VectorStyler said in Distribute objects with value?:
                @Igull To space objects at a fixed distance: open then alignment panel and from the panel menu enable the Alignment Options.
                Absolutely wonderful, works a treat - you've saved me a pile of time 👍 👍 👍
                So many easter eggs in VS 🙂
                Neil
                  encart @VectorStyler
                  @VectorStyler I wonder if it would not be better for negative values to reduce the space between objects. Currently, the opposite is true.0_1687538664974_screenshot_20230623_184210.png
                    VectorStyler @encart
                    @encart Depends on the order of the selection and the alignment direction.
                    • IgullI Offline
                      Igull @VectorStyler
                      Yes, works with both pos and neg values - I always have my alignment set by geometry by default.
                      Wish I had known this was here earlier - I've used it at least 5 times this afternoon LOL 🙂
                      Neil
                        VectorStyler @Igull
                        @Igull said in Distribute objects with value?:
                        For more tricks, you can setup other custom alignment types using the Alignment Schema from the alignment panel menu.
                          @VectorStyler wow! I had no idea this was even here! This is going to be fun
                            Found a while ago a another possibility to distribute Objects
                            in a unique way in VS.
                            But don't know exactly what it could be useful for.
                            Anyway, it works like this
                            Apply a transform Move to an object.
                            Set the number of copies and a distance
                            ( so far so normal )
                            now activate the option "Transform each"
                            VS adds then the object distance value upon each copy step
                            (e.g.) distance 10
                            first 10, second 10+10 (20), third 20+10 (30) and so on...
                            recorded a video
                            • IgullI Offline
                              Igull
                              @Subpath I'll add that one to my knowledge list 🙂
                              I'm sure a use will turn up at some point !
                              Neil
                                Subpath @Igull
                                i thinking that way too 🙂
                                you never know
                                  @Igull
                                  is even possible to do some Math here
