Change width/height by 10 using SHIFT
Ok, so in previous versions when you opened the Transform Panel, placed the cursor into the W field (width), held SHIFT and used the up/down arrow keys, the values used to change by the increment of 10. Now it's only changing by 1. Was this changed? If so, why?
I don't see anything in the preferences where I can control this. I trashed the "VectorStyler1.0" folder to reset everything, still it's just increasing by 1. Everything else (except for width and height) is changing by 10.
in my tries with 1.1.099
only the scale and the rotation fields
change their value with 10 by holding shiftx,y and width and height fields change by 1
holding shift -
Hmmm... yeah, I just retrieved 1.1.099 from the trash and I'm either being swallowed by a black hole or getting dementia cuz I've been using this feature a lot and I could swear it used to increase by 10 when holding SHIFT. Maybe I need to see a doctor...
Anyhow, thanks for checking @subpath!
Mine is working fine, VS1.1.100
Preferences>Adustments
You can set it up at
And,
Size Presets: Stroke Width,Brush Eidth, Font Size
have been reset by a clean install?
I use an app cleaner to remove all traces of VS, so yeah, everything starts from scratch. Yes, I have went through the Preferences, but those values that you are showing have nothing to do with the width and height of the object.
This one I'm talking about:
Ah, NEVER MIND! I just realized everything was reset the the values were in points. In the previous version I set my new document preset to be in pixels. So once I change that, SHIFT will adjust the values by 10 pixels.
Thanks anyways, guys! I better create and save a document preset for pixel values...
@pentool said in Change width/height by 10 using SHIFT:
That's good to know.
This correlates with an observation that I noticed, that there are no
decimal places in the fields with steps of 10.Which is the case with the pixel unit also the scale fields with % and rotation.
@pentool I cannot replicate this issue, it is working fine here.
One thing to try is to reset the app preferences. -
I had a similar issue, the keyboard shortcuts for 'nudge more' /left/right/up/down (shift arrow) had 'unknown command' next to them - I just removed the commands and made another four - then saved the command set - solved my problem - YMMV
Neil
