    Issue with the Variable data export
    6 Posts 2 Posters 6.1k Views 2 Watching
    • L Offline
      Li Xiao
      test.csv
      0_1696672318685_TEST.zip
      0_1696672441625_Variable data export bug.vstyler
      https://youtu.be/8XygUyaTybY
        VectorStyler @Li Xiao
        @Li-Xiao Added this to the backlog.
          @Li-Xiao Using the data source in the repeater and for export results in a conflict and the variables are not resolved.
          I will try to find a way for this to work.
          In this case it might be that the repeater should ignore the export data source, but there still will be one exported file per data row.
          L 2 Replies Last reply Reply Quote 0
          • L Offline
            Li Xiao @VectorStyler
            Thank you
            When exporting PDF files, it would be ideal to have the option to specify the desired data.
            For example, with a quantity of 1000, I would like to have only one PDF file, and with a quantity of 5000, I would like to have two PDF files.
            • L Offline
              @VectorStyler Actually, all of about exporting variable data is problematic.
              0_1696761599167_TEST.zip
              0_1696761629169_VD TEST.vstyler
              https://youtu.be/owx_-NW79gc
                @Li-Xiao said in Issue with the Variable data export:
                Opened a bug on this one.
