    Panels disappear when VS works in background
    18 Posts 3 Posters 16.6k Views 2 Watching
      VectorStyler @encart
      @encart said in Panels disappear when VS works in background:
      @VectorStyler To get everything back to normal you have to change the tool.
      What if you just click inside the canvas once?
        @VectorStyler This is related to the overall topic so I am adding it here.
        If I am using the 1.2.2 beta, if I click on another program, VS completely hides, not just the panels but the entire program. What I was discussing earlier in this thread was that it was normal for the open panels to hide when clicking on a different program. I'd like to clarify that the main workspace should still remain in view. This is what the other programs do.
        A real life example - I wanted to use a font finder program to see what a particular font was used in a design in VS where the font had previously been expanded. I open the font finder app and it needs to take a screenshot of the desired font shapes to scan the database. If I click on that program, the entire VS workspace disappears, which is not ideal and is a little jarring.
        I understand the concept of what you were intending and it can be useful some of the time to get VS out of the way so another program can be used - it's just that I spend much of my time jumping over to another program temporarily and want to keep VS on the screen. I don;t know a great way to make it work for both cases
          @Boldline said in Panels disappear when VS works in background:
          This should not happen. Did this occur on macOS Ventura?
            @VectorStyler yes this occurs in Ventura. I have not upgraded to the newest os as of yet.
            I just checked this on a different computer and its working normally, the VS workspace does not also minimize... So the issue is related to something local to the first computer. What would I need to send to you to narrow in obtaining the cause?
              @Boldline Send me the settings and workspace files (better just zip the /resources/ folder as there are more files now in 1.2).
                @VectorStyler I was able to replicate the issue several times yesterday but today it's working as it should.
                  @Boldline Could it be related to some specific panel being open, or docked to the main window.
                    @VectorStyler ok I'll keep an eye on it and take note of what panels are open and what is docked if it happens again.
                      @VectorStyler said in Panels disappear when VS works in background:
                      Thank you for bringing up this possibility because it happened again! When I have only the blend panel docked on the right side but not completely collapsed to icon only, it will hide the whole VS workspace when I click on another application. If I remove the blend panel from the docking position and either shrink it to icon only or pull it free completely, the VS workspace does not hide.
                      I tested this with some other panels but did not have the same error occur like I did with the blend panel
                      UPDATE: tested this example with the blend panel docked but not icon-only on my laptop and the same issue occurred there as well
                        @Boldline Replicated!
                          Awesome!!! Glad you could replicate it
