    Indicators showing while invisible
    7 Posts 2 Posters 6.8k Views 2 Watching
    • AyoA Offline
      Ayo
      Visible and editable while invisible
      Working with Node tool.
      • Why are objects indicators visible and editable while layer is set to invisible?
      • Red rectangle should have red color indicators (set to 'Layer')
        VectorStyler @Ayo
        @Ayo (1) is by design. If an object is not locked and is selected (in the layers panel) then it will be editable.
        (2) might be a bug, I will try to replicate it.
        • AyoA Offline
          Ayo @VectorStyler
          (Fig. 2) An object should not be editable (and not visible by indicators) if it is set to invisible in my opinion. However, now it does.
            VectorStyler @Ayo
            @Ayo said in Indicators showing while invisible:
            I have to look into this more to better understand what is expected of invisible objects. Sometimes these can be inside groups, etc and changes will apply to them (unless locked).
            • AyoA Offline
              Ayo @VectorStyler
              There is nothing complex about the situation. Let me illustrate it again using the simple example below. But if a document becomes more complex, this can be very annoying.
                VectorStyler @Ayo
                @Ayo I added this to the backlog and will try to find a solution.
                • AyoA Offline
                  Ayo @VectorStyler
                  @VectorStyler said in Indicators showing while invisible:
                  find a solution
                  Perhaps 'Invisible = locked too (in the background)'? Locked can be visible.
