About the two bugs related to selection
- The issue of shapes generated by the Repeater being added to the selection.
- The problem with assigning form selection, where only one shape is retained.
0_1698059255882_Selection bug.vstyler
https://youtu.be/07pWl9o-rOo
@Li-Xiao Can be replicated here also, clearly a bug. Will be fixed ASAP.
@VectorStyler Creating a new copy can solve the first problem, but it is not a good solution if there are too many shapes.
Additionally, there is another issue that may or may not be a bug, where overlapping the previous name results in duplicate names.
https://youtu.be/cNG6ZwrlMgE -
@VectorStyler Thank you, the first issue has been fixed.
After assigning new values to the preset values of the selected object, there is only one object, and the issue has not been fixed yet. -
@Li-Xiao said in About the two bugs related to selection:
Did you remake the repeater? The problem was with the objects created by the repeater.
@VectorStyler This issue is unrelated to Repeater. There are also problems with content that is not make by Repeater.
@Li-Xiao Send me the file with the problems
@VectorStyler two bugs has been fixed. Thank you.
