    Settings: retain certain values
    31 Posts 3 Posters 46.2k Views 3 Watching
      VectorStyler @B-Vs-V
      @Pat I will try to replicate this.
      • B Offline
        B-Vs-V @VectorStyler
        @VectorStyler Again I have this same issue. VS opens without toolbox and many docked panels although it indicates that the right workspace is in use:
        VectorStylerV B 2 Replies Last reply Reply Quote 1
          @Pat said in Settings: retain certain values:
          I opened a new bug on this one.
          • B Offline
            @VectorStyler I hope you could fix this bug. Always reloading the workspace each time you open the software is not very time-consuming but a bit annoying. I'm looking forward to installing the next update ☺
              It is still in the list of bugs, I will try to have it for the next build.
                encart
                I'm not sure if this will help, but I think it might have something to do with this bug. A few days ago I hooked up a second monitor as a desktop extension. I dragged some panels there. After unplugging the second monitor VS still remembered the coordinates of the panels' positions. I tried selecting and deselecting them in the menu, but they did not appear. Only when I reloaded the .workspace file did it return to normal. Maybe in this case, too, the panels appear somewhere off-screen?
                  VectorStyler @encart
                  @encart said in Settings: retain certain values:
                  Could be a separate bug, but it is a bug nevertheless. I will try to replicate and fix this also.
                    In beta 1.2 the workspace is kept after the restart (at least here). I also tested with the workspace you sent me (regarding the Pen tool bug, which BTW was replicated).
                    • B Offline
                      @VectorStyler said in Settings: retain certain values:
                      I've restored defaults WKS, reposition some panels without reducing those & so far so good. The Tool box and the panels are always there when I open VS beta.
                      Great you could reproduce the issue ☺
                      • B Offline
                        B-Vs-V @B-Vs-V
                        @VectorStyler Still there when I reduce some panels. It is fine with "normal" non-reduced panels even after resetting VS.
                          I could not replicate this yet. Send me the workspace and settings files from the /resources/ folder
