    Node tool on shape adjustment crashes VS
    11 Posts 2 Posters 10.3k Views 2 Watching
      VectorStyler @B-Vs-V
      @Pat Tried to replicate with that sequence of effects, but it works here.
      Send me that example.
      B 3 Replies Last reply Reply Quote 0
      • B Offline
        B-Vs-V @VectorStyler
        @VectorStyler said in Node tool on shape adjustment crashes VS:
        @VectorStyler File sent (artboard 3) ☺
        • B Offline
          @VectorStyler The crash is not immediate, but it happens every time.
          • B Offline
            @VectorStyler I'm sending you the same file with a new object (contour) that shows an unwanted offset.
            VectorStylerV B 2 Replies Last reply Reply Quote 1
              @Pat Got it.
              • B Offline
                @VectorStyler I've reopened this file and I'm wondering whether you were able to identify the contour bug? Thanks ☺
                  @Pat said in Node tool on shape adjustment crashes VS:
                  I tested the file and I could not replicate the crash. I will review the crash logs.
                  • B Offline
                    B-Vs-V @B-Vs-V
                    @VectorStyler the contour offset is still an issue in the last build.
                      @Pat Can be replicated here also, could not fix it yet.
                      EDIT: as a workaround, try placing the contour and its source path into a different layer.
                      • B Offline
                        @VectorStyler Grouping "solved" the issue ☺
