    Where do I adjust the node default size in the new beta?
    13 Posts 5 Posters 12.2k Views 4 Watching
      Subpath @Boldline
      there are a "Indicator Styles" Section in the Settings
      maybe there ?
        don't know if anyone has brought this up before, I believe
        in the settings the section part on the left needs a scroll bar
        As it is, there's no indication that you could scroll there
        and there are even more options
          Boldline @Subpath
          @Subpath said in Where do I adjust the node default size in the new beta?:
          maybe there ?
          Thanks for replying. I had checked there before and not found it. I had asked this same question a long while back and gotten the answer, but with the new beta, everything is rearranged
          • L Online
            Li Xiao @Boldline
            @Boldline I tried it, and there is no issue.
            https://youtu.be/BGp6bROQfq4
            BoldlineB S 2 Replies Last reply Reply Quote 3
              Boldline @Li Xiao
              @Li-Xiao Thanks - I was thinking of it in a different frame of mind; that there would be small, medium and large option sets to click on like Affinity used to do... not that I was somehow using a large circle as opposed to a small one. I appreciate the help!
                Subpath @Li Xiao
                @Li-Xiao
                thanks from me too, was also helpful for me
                to know
                  @VectorStyler Going back to this topic again.
                  While I appreciate what @Li-Xiao demonstrated in terms of editing the standard node size, it does not seem to make any difference here on my M1 Mac laptop. As you can see in the full screen capture image, the nodes and indicators for the path are huge and in the first screenshot, you see I went ahead and made sure the standard shape was small
                  For comparison, using the same settings on my M1 Mac Mini with larger screen, the nodes and handles look much smaller in comparison
                  0_1700292542374_3d2f6ee8-0457-4250-a608-63b1176e37b8-CleanShot 2023-11-18 at 01.26.00.png
                  0_1700292325083_46a604a4-fb08-4e9a-af50-573fd630f68c-CleanShot 2023-11-18 at 01.24.02.png
                    Boldline @Boldline
                    @VectorStyler Just for testing purposes, I set the settings back to the default and made a new document and used the pen tool and again, all the nodes and handles and even the artboard title are all super-sized in a bad way
                    0_1700293189664_52aa54d4-5baf-4cb7-8a2d-a9de6ff1a814-CleanShot 2023-11-18 at 01.38.20.png
                    This is what my laptop screen resolution settings are:
                    0_1700293358143_5e2ef1fd-ea42-48dd-9fd5-2269caf0761e-CleanShot 2023-11-18 at 01.41.28.png
                      Boldline @Boldline
                      @VectorStyler I will check this on my Mac Mini as well later today and report back. I will look at the size of the nodes and handles and the like as well as the rounded corners, if the adjustment cursor icon is activated in the correct spot or off like it is on the laptop
                      What about adding the ability to choose between small medium and large node indicators overall? Yes, right now there is the option for small medium and large circles and squares and the like to represent the node, but what about adding a relative scale the that as well?
                        @Boldline There is a bug here, I will try to replicate it.
                        • K Offline
                          Kumr @VectorStyler
                          @VectorStyler In my Mac cursor text cursor looks very odd.
                          https://recordit.co/iGm1T8HKr1
                            VectorStyler @Kumr
                            @Kumr Could be related. I will improve this.
