    Problem: Scaled strokes the retain the same width even though transform stroke is on
    5 Posts 3 Posters 4.6k Views 3 Watching
    • RaaskotR Offline
      Raaskot
      An element containing blends:
      When trying to scale strokes the width remain the same even though transform stroke is on. Am I doing it correctly?
      Kindly,
      Mikael
      Screengrab: scaling an element containing blends
      File: 0_1704987467769_ikoner.vstyler
      L VectorStylerV 2 Replies Last reply Reply Quote 1
      • L Offline
        Li Xiao @Raaskot
        @Raaskot It seems like a bug. Using the options on the Transform panel works fine.
        https://youtu.be/As8zTJrEfa8
          VectorStyler @Raaskot
          @Raaskot Could be a bug, I will try to fix this ASAP.
          • RaaskotR Offline
            Raaskot
            ☺ Thanks
            option-shift-S and option-T:
            Neither panels work.
            Transform panel
            Scale panel
            Kindly, Raaskot
              @Raaskot Meanwhile I managed to replicate the issue and found the root cause. The fix will be in the next build.
              The bug affects the strokes resulting in the blend object.
              The transform panel option @Li-Xiao was refering to can be found in the panel menu.
              Another way (workaround) to enable stroke scaling is to enable the Object -> Object Options -> Geometry -> Transformed Stroke on the group.
