Repeater feature: space between objects
I'm testing the Repeater feature and although the space between repeated objects is zero, I notice a line separating them when I export as a jpeg.
A pdf file is fine.In VS:
Jpeg file:
Pdf file:
@Pat Yes, this is a VS rendering artifact caused by anti-aliasing. It has been reported before, but I do not yet have a solution for it, other then setting up a small overlap.
I will try to find a solution. -
@VectorStyler thanks for the comment
I hadn't read that this problem had already been reported. -
Pat This kind of "touching edges" rendering artifacts exists with anti-aliasing in certain kind of rendering algorithms.
I think Affinity has them too.
The problem is that I do not yet have a solution that does not degrade the rendering performance.
