    Pdf export: All text turns into gibberish
    5 Posts 3 Posters 5.9k Views 3 Watching
    • RaaskotR Offline
      Raaskot
      I (still) have issues with pdf export from VS: All text turns into gibberish.
      Only when "Vector Text" is turned on it renders legible, but then text selection in exported pdf is not possible.
      Is there any other way I can solve this?
      I've attached vstyler and pdf-files
      0_1707254026574_pdf-font-messup-vstyler-pdf.zip
      Kind regards,
      Raaskot
        b77 @Raaskot
        @Raaskot It works here as it should but I don't have the Cachet typeface so
        I changed the font to SF Pro:
        0_1707263847991_pdf-font-OK.pdf
        Is the same happening with any font?
          VectorStyler @Raaskot
          @Raaskot Could be something to do with the font. I will try to replicate and fix this issue.
          RaaskotR 1 Reply Last reply Reply Quote 1
          • RaaskotR Offline
            Raaskot @VectorStyler
            Thanks.
            I have no issues with that particular font elsewhere. I submit a sample from Inkscape.
            The second example is from VS. Titillium font works somehow ok and the Cachet font only partly appears correct.
            0_1707296073048_text-inkscape.pdf
            0_1707296103898_text-vs-titillium.pdf
            The latter example displays a dire overall designproblem I have with VS:
            Typesetting is incredible cumbersome, unpredictable and very unstable. I.e. it seems to be very difficult to change line spacing for the Titillium. Have a look:
            Change leading in VS
            Things done swiftly in other programme takes an eternity in VS. I regret to say VS' type management works utterly strange.
            Kind regards,
            Mikael
              @Raaskot said in Pdf export: All text turns into gibberish:
              I have to replicate this. The Leading attribute set in the Character panel is applied only to the highlighted characters.
              There is also a leading property in the Paragraph panel for whole paragraphs.
