    How do I reset the gap between the dashes (dots) to even spacing?
    5 Posts 2 Posters 7.0k Views 1 Watching
      I'm sure this is very simple to do but I'm not seeing where the setting is to reset the spacing between the dots I created using the dash portion of the stroke panel. thanks for any help!
      0_1710607985230_a06138aa-4143-4cc0-91ef-4647cfdcd6b7-CleanShot 2024-03-16 at 12.49.04.png
        @Boldline The only way is to edit the dash and use only two values: space and dot, where the space sets the amount of space and the dot is zero length.
          @VectorStyler said in How do I reset the gap between the dashes (dots) to even spacing?:
          ok that makes sense but I'm not seeing where that is an option. I tried all the settings I thought would do that including the gap in the dash settings. would you please show a screenshot or be more descriptive of where the "space" setting is? thank you for your help
            @Boldline https://recordit.co/JtriZNkeP8
              thank you for the video, I must have some other setting wrong elsewhere because when I do those steps, I still get the odd spacing. here is a video of my attempt
              I will try on my other computer and see if I have the same issue so I know if it's a setting here on the first machine that I have wrong
              UPDATE: I see where the issue lies - I was going back to another setting in the dash dropdown and that was resetting the number of spaces again. Thank you for your help!
