Deactivate preset folder but keep it in sight?
@VectorStyler said in Deactivate preset folder but keep it in sight?:
create the restricted presets in the default group
How to do that
A group can be "hidden" using the (x) button at the end of the group title row.
Oops! now I have removed the Arrows group from the presets panel. Don't know how to get it back now
Deactivate–Activate
This was my suggestion / idea to make life easier.
For notification
@Ayo said in Deactivate preset folder but keep it in sight?:
If preset groups were hidden, the Presets panel menu will contain a "Reveal Hidden Presets" that resets the whole thing to all groups visible.
Got it back!
Presets Menu > Reveal Hidden PresetsIf not applicable > not visible
Other inapplicable options in that list are gayed-out by the way.
Prefer grayed out. For notification -
EDIT: this I have to think it over. There are a lot of other menus showing/hiding depending on availability.
Cannot have them all showing in grayed out mode.Some commands are prioritized for info, and those will show greyed.
Tried keeping the default arrow set (Export Group) to see if I could delete the group as well.
Did export and get a very long list of all presets? including selected. Is this correct?
Yes, all the presets were copied from that group (exports the whole group).
The Options button opens other exporting options.
Getting a little confused by the term 'Group'. Does this have two meanings in Presets?Preset Group folder (Create Preset Group) & Presets Group as a whole?
It has a single meaning, it is a Group (or collection) of presets of all kinds of types.
A group of presets is stored in a folder, with each preset type (arrow, dash, pattern, brush, etc) in a separate file.
You can create new groups that are always loaded / stored in a folder. When storing presets in these user folders, it is easier to back them up, share them, etc.
I know what a group means, but it's about naming in the menus, panels and documentation to keep things apart. Let me explain...Presets Group n.1
If I say 'Create New Folder' in the Preset Manager menu, I get a popup with 'Create New Group'. The pre-filled text then says 'Group'. You can then complete the name yourself. For example, I create 'Group my Arrows' folder.Presets Group n.2
Button 'Export Group' in the Preset Manager means export the whole group of all the presets. All 51 types that exist, arrows, gradients, patterns etc. Not 'Group my Arrows'This is confusing
Suggestion:
Preset folders & Preset Groups -
This should export only the types in the current group. I will open a bug on this to verify it.
