update 1.2.034
VectorStyler 1.2.034 release notes
- Automatic update of document when fonts are registered.
- Improved CVS file importing for data sources.
- Add stroke transforming options to stroke popup view.
- Fill and stroke options in context panel when bucket fill tool is active.
- Keep active palette when selecting layer color.
- Fixed a regression in deselecting nodes.
- Do not register spot color when selecting from document palette.
- Improved object repetition from the object transform view.
- Keep fill and stroke in single object when importing SVG files.
- Show some nodes of complex shapes also when hovering.
@VectorStyler "Add stroke transforming options to stroke popup view" - Is this the same as Adobe Illustrator's Scale Strokes & Effects feature?
@gotanidea Only the Scale Strokes part, but it is a non-destructive option that already existed in the panel, it was just missing from the popup.
@VectorStyler said in update 1.2.034:
This is great! thank you for adding this and allowing bucket fill to work with enclosed strokes. so easy and smooth to choose colors for fill and/or stroke while using bucket fill tool
Thanks for the update. Again better!
When Document palette menu "Register Spot Color" is off. Then when using a palette color, palette does not register spot color. That's ok now. But it does register a new Process Color. Can not turn that off in p. menu. Intended? -
When could we expect the destructive Scale Strokes and Effects feature to be added to VectorStyler? It's very important for line-art and comic illustrations
@Ayo said in update 1.2.034:
The document palette menu should not register colors now. If it does, it could be an error, I have to check this.
@gotanidea said in update 1.2.034:
This is in the 1.3 backlog, I will try to bring it earlier if possible.
Also grateful for this fix - speeds up my workflow considerably to have it working properly again. The pen tool and node editing tool work so well now, it reminds me of all the steps made to improve it along the way - thanks!
Thanks again for the continuous updates.
