    what file format from Shortcut Presets in vector styler
    3 Posts 2 Posters 3.7k Views 2 Watching
    • R Offline
      re
      what file format from Shortcut Presets or/and Keyboard Presets does it support? to import it into the software I would like to import the adobe-illustrator-cs2.xml but I can't and not what kind of file is needed to do this.
        VectorStyler @re
        @re The file format is internal to VectorStyler (it is in XML), so you cannot exchange with Adobe Illustrator.
        The problem here is the different action set of VS and AI.
        But I will add to the backlog to look into if AI shortcut format could be (partially) supported.
          VectorStyler @re
          @re said in what file format from Shortcut Presets in vector styler:
          Can you send me this cs2 shortcut file by email to csraba at vectorstyler.com I only have AI CC, I'd like to check if these are compatible.
