    Duplicating a Path Section - per manual, doesn't seem to work
    13 Posts 3 Posters 9.2k Views 4 Watching
      Subpath @VectorStyler
      doesnt work via ALt+key here too
      but via Transform > Move
      see video her
      P VectorStylerV 2 Replies Last reply Reply Quote 1
      • P Offline
        pentool @Subpath
        @Subpath Must be a windows issue. It works for me with Option on the Mac but have to select 3 or more nodes.
          Subpath @pentool
          @pentool
          curious, it doesnt work with the Alt-key on Windows
          but via Menu >Object > Transform > Move
          it works with also with just two nodes
          if i select just one Node this way the whole Path will be copied
            Subpath @monsterfox
            @monsterfox
            I don't know how this happened,
            but your post here is in the wrong thread
              VectorStyler @Subpath
              @Subpath said in Duplicating a Path Section - per manual, doesn't seem to work:
              I will test this on Windows.
                VectorStyler @pentool
                @pentool said in Duplicating a Path Section - per manual, doesn't seem to work:
                any section of a path between two nodes
                Yes the wording might need to be changed. The two node selection case does something else (stretching rotating the path section).
                  @pentool
                  I tested this on Windows, doe to some other features, the Alt key must be pressed after starting the node movement.
                    got it, thanks
                    But that is not necessary if i copy a Shape via the Alt key
                    Also curious, that this way works only with 3 Nodes selected as a minimum,
                    but copy only 2 Nodes work if a use the way via Transform Move
                    which i showed above
                    For anyone who is reading this:
                    To copy a part of a Path on Windows
                    select minimum 3 Nodes
                    select any of that 3 Nodes hold the left Mouse Button down
                    (selecting the Path doesnt work)
                    press the Alt-key then and move the Part of the Path
                    and that Part will be copied
                      @Subpath The 3 node limit is because of a conflict with an other feature, where the Alt+ with 2 node selection will stretch the section between the two nodes.
                        @VectorStyler said in Duplicating a Path Section - per manual, doesn't seem to work:
                        understand, have no Problem with that, (just wondered)
                        if i need it i will add a node if necessary and deleted it later on
