    A small detail - Removing an unfound file from the list
    11 Posts 5 Posters 9.4k Views 4 Watching
    • B Offline
      B-Vs-V
      It's a detail, but I still sometimes have to read this text because my humble personal logic would suggest that if the file is not found, its name should disappear from the list. I would reverse this text & action:
        VectorStyler @B-Vs-V
        @Pat Added to the backlog.
          monsterfox @VectorStyler
          @VectorStyler Such a dialog box. The Tab key is not working. Can it be added?
            VectorStyler @monsterfox
            @monsterfox said in A small detail - Removing an unfound file from the list:
            Will do so.
              The fact that the file is not found here and now does not necessarily mean it no longer exists. It could be that an external SSD, a USB drive, or a network drive has not been connected, which often happens in various situations on a company laptop that is on and off the network.
              All frequent scenarios for my usage and work situation.
              • B Offline
                B-Vs-V
                VS won't let you find the file via this dialogue box anyway.
                  Ingolf @B-Vs-V
                  @Pat said in A small detail - Removing an unfound file from the list:
                  Not until I reconnect the drive - which I do. And then I need VS to remember the file and its path, thank you very much.
                    Boldline @Ingolf
                    @Ingolf said in A small detail - Removing an unfound file from the list:
                    I agree with this and would keep it in the list. maybe if an asterisk was added in the list to signify to was a missing file?
                    • B Offline
                      B-Vs-V @Boldline
                      @Boldline In that case, it's certainly better to keep the name in the list. As my PCs have internal hds several terabytes in size, I don't use external hard drives (except as backups).
                      • B Offline
                        B-Vs-V @VectorStyler
                        @VectorStyler I don't know if it's possible but it would be useful to see the location of the file by leaving the mouse pointer over the name of that list ☺
                          @B-Vs-V said in A small detail - Removing an unfound file from the list:
                          Not in the menu. The only option is to list files with complete folder name.
                          But it can show in the alert view.
