    update 1.2.046
    3 Posts 3 Posters 2.9k Views 2 Watching
      VectorStyler 1.2.046 release notes
      • Export transparent mesh gradients to PDF as images.
      • Fixed a Separate Path bug on composite shapes.
      • Fixed selecting multiple canvases in the Canvas panel.
      • Duplicated repeater objects to correctly detach on changes.
      • Allow selecting number variables from the Context panel (example: stroke width).
      • Repeating the Scale operation should use the correct center.
      • Do not show duplicate shape properties in the context panel.
      • Holding shift while duplicating should keep snapping on.
      • Do not snap to shape angles when point snapping is enabled.
      • Separating dashed strokes with profiles should split the profile correctly.
      • Show scaled font sizes in the panels.
      • Selecting spot colors should change the color only, not the tint.
      • Changing tint of spot colors should not change change the color.
      • Keep options for the Color Variations panel after a restart.
      • Add gradient flip button to various color and image effects using the gradient selector.
      • Disable image trace button if both storke and fill tracing is unchecked.
      • Undoing canvas data source selection should update the canvas.
      • Added automatic artboard count for canvas data sources.
      • Better cursor direction handling with text selection.
      • Do not show decimals in color palette list.
      • Do not add paragrapjh space before at the start of a frame.
      • Fixed a text wrap bug.
      • Fixed a regression in selecting Drop Capital and paragraph numbering options.
      • Fixed a bug in paragraph stretch options editing.
      • Fixed several tab stops related bugs.
      • Improved update of color panel with text fill or stroke info.
      • Detaching from iconified panel groups to remove section correctly.
      • Better default stretching options for justified text.
      • Allow slice renaming with mouse click in Slices panel.
      • Added option to select another node after deleting a node in the path editor.
      • Break apart the path when removing nodes with disconnect.
      • Set correct position of objects after releasing a repeater.
      S BoldlineB 2 Replies Last reply Reply Quote 8
        Subpath @VectorStyler
        impressive list, as always 👍
          @VectorStyler Impressive work! We appreciate your hard work and passion for the VS project
