    Node snapping
    9 Posts 4 Posters 6.1k Views 4 Watching
    • Z Offline
      Zero
      When using the pen or the node tool, is there a way to snap to nodes (in the current shape)? Eg. trying to draw a triangle: the third node should be able to snap to the other 2 nodes, see image below)
      VectorStylerV AyoA 2 Replies Last reply Reply Quote 1
        VectorStyler @Zero
        @Zero Not like that, only directly on the point.
        This kind of snapping can be added easily, the problem is that it will snap to the nodes of other paths also.
        Would that be ok?
        • Z Offline
          Zero
          That would be great! Actually snapping to nodes on other paths is a very welcome addition.
          • AyoA Offline
            Ayo @Zero
            @Zero said in Node snapping:
            I don't quite get the drawing and question but;
            maybe author Zero is looking for 'Snapping Options' > 'Snap to Original' ?
            (or more explanatory: 'Snap to Itself")
            That's provided.
            VectorStylerV encartE 2 Replies Last reply Reply Quote 1
              VectorStyler @Ayo
              @Ayo I think this was about independent x/y coordinate snapping for nodes. Currently the "Snap to Points" mode only snaps to the point both xy at the same time.
                encart @Ayo
                I also have trouble understanding the problem.
                But maybe this will help with something - if I want to stick to a point on the current path, I make a point somewhere next to it and without releasing the mouse I drag it over a point on the path When it is in the right place I let go of the mouse.
                Of course, I have 'Snap to Points' enabled
                https://somup.com/cZX2IdJrPd
                • Z Offline
                  Zero
                  Here is what i mean (from Affinity)
                  Hope this clarifies a bit.
                    VectorStyler @Zero
                    @Zero This will be in the next build.
                    Z 1 Reply Last reply Reply Quote 2
                    • Z Offline
                      Zero @VectorStyler
                      @VectorStyler said in Node snapping:
                      Awesome! Thank you.
