    update 1.2.054
    5 Posts 2 Posters 4.1k Views 2 Watching
      VectorStyler 1.2.054 release notes
      • Option to allow using (linked) object styles as default drawing styles.
      • Improved alignment of number sliders.
      • Converting a single glyph to curves should result in a single object, not a group.
      • Fixed a refresh bug when changing styles inside transformed groups.
      • Allow click selection of parametric shapes in the node editor.
      • Convert to curve should be disabled if no conversion is possible.
      • Show color palette margins inside popover views also.
      • Changed the popover window style.
      • Creating number variables should check for name overwrite.
      • Do not paste text into a shape text as a frame.
      • Improved exporting blend modes to SVG and PDF.
      • Fixed a bug in breaking apart cloned objects.
      IngolfI 1 Reply Last reply Reply Quote 8
        Ingolf @VectorStyler
        @VectorStyler said in update 1.2.054:
        Yeah, I suppose this is what made Verctorstyler beautiful again? 🙂
          VectorStyler @Ingolf
          @Ingolf THis change was about the removal of the pointing bubble frame around view opened from buttons
            Perhaps fixed my issue with panel corners as well? I believe something wonderful happened in this or the previous release.
              @Ingolf said in update 1.2.054:
              yes, some outlines are thinner now.
