      VectorStyler @Subpath
      @Subpath said in XLS for features and ideas - Mega Thread:
      any real reason to use drag & drop to color objects
      It is possible to color objects with drag&drop in VS,.
        Subpath @VectorStyler
        @VectorStyler said in XLS for features and ideas - Mega Thread:
        Thanks, interesting to know, but I don't remember ever using it.
        I've seen it in other programs i use, but I always found it a bit cumbersome.
        • DanielD Offline
          Daniel @Subpath
          @Subpath: it's incredibly useful and fast if correctly implemented. It allows you to change contrast of fx without cumbersome sliders.
          • DanielD Offline
            Daniel @VectorStyler
            @VectorStyler: it is the default transform tool but with modifier.
              VectorStyler @Daniel
              That is problematic, because then we don't know which effect / property is selected.
              • DanielD Offline
                @VectorStyler: How about then simply selecting the FX first in the yet-to-be-developed properties panel? Before the drag and drop?
                  I will think of a solution. For now the best I can think of is when the corresponding effect editor tool is active.
                  • DanielD Offline
                    Daniel
                    Spacing handles: Selecting multiple objects should switch on spacing handles. Spacing handles are both vertical and horizontal. These help in adjusting the space beween the objects without resizing them.
                    VectorStylerV DanielD 2 Replies Last reply Reply Quote 1
                      There is a Gap tool in VectorStyler, but that changes the object sizes.
                      • DanielD Offline
                        Daniel @Daniel
                        Spacing handles automatically distribute objects when used, so you can think of how to combine this with alignment handles suggested earlier.
                        • DanielD Offline
                          @VectorStyler: This need not be a separate tool. It is an act of transformation, therefore logically related to normal transform tool. 🙂
                          • DanielD Offline
                            Daniel
                            @VectorStyler: Ctrl + Shift + Scroll over fill to change hue, with on-canvas label to show HSL values. The same scrolling over stroke changes stroke width.
                            • DanielD Offline
                              Daniel
                              <<>> keys to proportionally resize objects by set percentages.
                              • DanielD Offline
                                Daniel
                                @VectorStyler: Transient zoom: Hold down a key for a set zoom percentage at mouse cursor location for as long as the key is held down. One implementation: Inkscape.
                                • DanielD Offline
                                  Daniel
                                  I went over all my previous suggestions and realised that a great number of them centred around improvements to the pen tool. So I am going to summarise them all in this thread for simplicity:
                                  1. Additional pen modes: Bezigon Model, Catmull Rom Spline and Arc Spline - See XDP (for CR), Gravit & FH (for Bezigon) and Boxy SVG (for Arc Spline)
                                  2. Interactive feedback for nodes and paths: See Lunacy & Boxy SVG
                                  3. Tab to next node with auto panning if node out of view: See XDP
                                  4. Merge Node Editing & Curve Creation: See GIMP
                                  5. Vector Networks: See VGC.io and Figma
                                  6. Lock Nodes: See PL
                                  7. Group Nodes: This is completely new.
                                  8. Implement Tangential Node: See FreeHand
                                  9. Allow 15-degree guides and snap to curve edges: See Graphite.Rs
                                  10. Allow subpaths: See Affinity & PL
                                  I invite other users to vote on what they think ought to be the order in which these improvements and ideas for pen tool should be. For me, right at the very top of the pile goes Bezigon and merging of node editing and curve creation capabilities. And Bezigon would require Tangential nodes and 15-degree guide to be meaningful. This would be followed by Lock and Group nodes.
                                    Some of these will be separate tools. In terms of clicks it is better, and then you can assign shortcuts to those tools.
                                    1. Interactive feedback for nodes and paths: See Lunacy & Boxy SVG
                                    I have to learn more about this.
                                    1. Tab to next node with auto panning if node out of view: See XDP
                                    Yes.
                                    1. Merge Node Editing & Curve Creation: See GIMP
                                    Problematic. Both tools are already overload the existing modifier keys. But it is possible to switch temporarily.
                                    1. Vector Networks: See VGC.io and Figma
                                    Yes, but later.
                                    1. Lock Nodes: See PL
                                    Possibly yes.
                                    1. Group Nodes: This is completely new.
                                    Same as above.
                                    1. Implement Tangential Node: See FreeHand
                                    I have to learn more about these. Any examples?
                                    1. Allow 15-degree guides and snap to curve edges: See Graphite.Rs
                                    Not sure, but both of these might exist. Guidelines can be rotated to any angle, and then there is Collision snapping mode.
                                    1. Allow subpaths: See Affinity & PL
                                    I think these are supported. Just use the Combine path operator.
                                    • DanielD Offline
                                      That's fair. Works for me.
                                      This is a quality of life improvement. This can wait.
                                      Perhaps, there's a misunderstanding here. I'm not suggesting that we getting rid of the node tool. The node tool should exist on it's own. But the pen tool should be able to manipulate both nodes, handles, add, delete nodes, and so on. I will record a video to demo this clearly. Once you see it, you can assess if it's possible. This circumvents the need to use modifier. It is highly intuitive and useful. Combined with other modes previously suggested, it would be supremely meaningful.
                                      I will record video for this.
                                      Will need to check this further to see if it works as it should.
                                      It's not about combining path. It's about continuing to draw separate curves as a part of a single path. Is that how it works?
                                      VectorStylerV L 2 Replies Last reply Reply Quote 0
                                        No. Is this about continuing to add curves to a single path? Show me some examples.
                                        • DanielD Offline
                                          @VectorStyler: Yes. I can discontinue a curve. Click somewhere else, and it would be considered a single path. I will record video later this weekend.
                                          • L Offline
                                            lilith @Daniel
                                            @Daniel said in XLS for features and ideas - Megathread:
                                            ''But the pen tool should be able to manipulate both nodes, handles, add, delete nodes, and so on.''
                                            Are you talking about Affinity Designer‘s pen tool
