Polygonal Spiral needs to add rotate parameters
The shape feature in VS has the largest variety and the most adjustable parameters among all vector software. However, the Polygonal Spiral is missing a rotational parameter, and I hope it can be added. It is quite challenging to create the image provided at (https://vivekseth.com/client/parametric-drawing-canvas/images/advanced-4.png) without a rotational parameter. Having a rotational parameter would greatly simplify the process and maintain non-destructive effects. I have also attempted to create it using VS.
https://youtu.be/eMMwIidEzIw
@Li-Xiao I added this to the backlog.
@VectorStyler Thanks.
There are also patterns like the one shown in the image, but I have been unable to replicate it.
@VectorStyler Rotation is now functional, thank you very much.
Looking forward to waveform rotation.
@Li-Xiao said in Polygonal Spiral needs to add rotate parameters:
Do you have some examples for this?
examples 0_1713254884258_Polygonal Spiral.pdfIt seems like there is a missing option when creating a spiral star shape
0_1713254910259_spiral star.pdf
@VectorStyler Thank you very, very much. it's even more impressive than I imagined.
@VectorStyler During use, it was also found that two options were missing:
The corner radius values for polygon spirals lack customization for inside and outside separately;
https://youtu.be/hVoS3urnqLY -
Spiral and polygon spiral need to support custom shapes.
it is not clear how this would work for spiral?
@VectorStyler If Polygonal Spiral can create elliptical spirals, there is no need to modify Spiral. This feature is commonly used in laser engraving, and there are plugins in CorelDraw that offer this function, but I dislike the subscription model.
Send me a link to this.
@VectorStyler Offset can solve some problems, but decay doesn't work.
