    UI language translations (BETA)
    27 Posts 8 Posters 21.3k Views 8 Watching
      VectorStyler @roychen
      @roychen Restart VS and the Settings -> Application -> Language (beta) should be enabled for you.
      L 2 Replies Last reply Reply Quote 0
      • L Offline
        lcfw
        The Chinese beta version has finally arrived, and I have been waiting for it. Please provide me with the Chinese version for testing. Thank you
        • L Offline
          Li Xiao @VectorStyler
          @VectorStyler I can spare some time to test it.
          • Devil DinosaurD Offline
            Devil Dinosaur
            I can help on French version
            Fred.
            • L Offline
              @VectorStyler An obvious issue with the Chinese interface is that the text is not fully displayed, especially on the panels. I have tried different settings and even set the system display to 100%, but the problem persists. I will review everything and point out the problematic areas.
              Properties Panel
                VectorStyler @Li Xiao
                @Li-Xiao Got it, this seems to UI font issue on Windows. I will try to fix it for the next build.
                • L Offline
                  @VectorStyler Suggest changing '普通话' to '简体中文'
                    @Li-Xiao said in UI language translations (BETA):
                    Wil do so. There is also a UI font issue on Windows.
                      @Li-Xiao The new build contains some improvements for the translations also.
                      The Chinese language display should be fixed, but it might depend on the selected UI font if that was customized.
                      • L Offline
                        The Chinese interface is displaying correctly over 95% now. However, 'Simplified Chinese' has become 'Traditional Chinese'. There are still some minor issues with a few panels.
                        In version 1.2.073, the Chinese UI is Simplified Chinese (简体中文), while in version 1.2.074, the Chinese UI is Traditional Chinese(繁體中文). It's best to keep both, as Mainland China uses Simplified Chinese, while Hong Kong, Taiwan, and Macau use Traditional Chinese.
                        Most software with Chinese interfaces provide both Simplified Chinese and Traditional Chinese options, such as Adobe and Corel....
                          I will include both in the next build.
                          L 2 Replies Last reply Reply Quote 1
                          • L Offline
                            @VectorStyler The presets in the Mask options of the Transparency panel, Properties panel, and Image Effects panel are not translated.
                              @Li-Xiao Yes, most of these "extra" preset names are fixed (not part of translation).
                              I will try to add these to the translated text also.
                                VectorStyler @VectorStyler
                                @VectorStyler In general some things that are not translated can be: preset names, recorded or recent action names, and various names (like canvas, or layer) saved into documents.
                                • L Offline
                                  Two types of Chinese can be consistent like the two types of Portuguese.
                                  中文(简体)
                                  中文(繁體)
                                    @Li-Xiao Yes, I have the translation, and I will include it into the next build.
                                    But the next build will come a bit later.
                                    • 861475_VctSt8 Offline
                                      861475_VctSt
                                      I'd like to try Japanese.
                                      Please set it up.
                                      I have two licenses.
                                      Thank you.
                                      LIc. 0 OS10.15.8
                                      LIc. 1 OS15.8.3
                                        VectorStyler @861475_VctSt
                                        @861475_VctSt said in UI language translations (BETA):
                                        I enabled for one of license associated with the email from this forum account.
                                        Email me if you need for other emails also.
                                        861475_VctSt8 2 Replies Last reply Reply Quote 0
                                          861475_VctSt @VectorStyler
                                          I have emailed you about the other license, so please set it up.
                                          LIc. 0 OS10.15.8
                                          LIc. 1 OS15.8.3
                                            I was able to localize the UI language for both licenses.
                                            Thank you.
                                            LIc. 0 OS10.15.8
                                            LIc. 1 OS15.8.3
