    Bug: Duplicated text frame does not reflow after resize
    5 Posts 2 Posters 1.2k Views 2 Watching
    • J Offline
      jpsimmons
      Version: 1.2.085 (macOS)
      Problem
      After duplicating a text frame, resizing the duplicate does not reflow the text using the new frame width.
      Instead, VectorStyler applies an affine transform to the visible text:
      • The text is scaled uniformly with the frame.
      • The internal wrap width stays frozen at the original frame’s value.
      • If the text previously wrapped, the wrapped region remains truncated — scaling does not reveal any hidden text.
      Expected
      Resizing a text frame should recompute the text reflow based on the new frame geometry, not scale the contents. This is how InDesign, FrameMaker, Quark, and Acrobat behave for non-linked text frames.
      Why it matters
      The current behavior exposes internal layout state and treats simple text as a graphical object rather than a typesetting container.
      Request
      • Update the internal wrap width whenever the frame is resized.
      • Optional: add “Reset Text Wrap to Frame” to manually recompute reflow.
      Steps to reproduce
      1. Create a text frame with wrapped text
      2. Duplicate it
      3. Resize the duplicate
      4. Text scales but does not reflow; wrap width remains the original width
      VectorStylerV 3 Replies Last reply Reply Quote 1
        VectorStyler @jpsimmons
        @jpsimmons I opened a bug on this
          @jpsimmons if there is an example file, it might help a lot. Thanks!
            @jpsimmons This only happens here when the duplication mode is set to "Reference", or the Edit -> Reference command is used to duplicate.
            If that was the case, this is a normal behavior as a symbol is created from the text frame and scaling the "duplicate" scales the symbol.
            • J Offline
              jpsimmons @VectorStyler
              @VectorStyler I can provide one-it's on my other computer-I'll make a note to upload it.
              I had problems reproducing this until I remembered that the original graphic was converted from Illustrator. Native VS graphics don't have this problem. Looks like a metadata problem with conversions.
