update 1.2.090
VectorStyler 1.2.090 release notes
- Fixed a clipping issue when exporting images to PDF
- Fixed a bug in selecting corners with the corner tool
- Fixed a bug in using reduced image resolution when exporting to PDF
- Convert to curves before breaking apart to keep stroke transform
- Convert to artboard should keep the object
- Shaped layers should move with artboards
- Fixed a bug in changing page format options for a single page
- Fixed a bug in repeater colorizer preview
- Fixed a bug in the Coverage intersection mode
- Fixed a bug in the solid stroke and remove stroke buttons in popover
- Opening path eraser tool with no selection should erase on canvas
- Flattening opacities should use document color mode
- Allow using grouped text on path as displacement effect mask
- Improved scrolling in the object roles list
Were there any changes in the display rendering in 1.2.090? I thought 1.2.088 was smoother when moving nodes. I see a slight jitter or flicker but maybe it's my machine.
@ai_slop No changes in rendering. You can try reinstalling the previous build to compare the rendering.
