    Dealing with colors
    27 Posts 4 Posters 53.1k Views 1 Watching
    • P Offline
      Petar_MK
      Yes, They can coexist, but why would you use them if there is an easier, better and faster way for appling colors?
        b77 @Petar_MK
        @Petar_MK OK, but it's not only about applying preset colors — many times you want to use the sliders to get the color you want, and the Fill and Stroke buttons are there to let you choose where the color is applied (to the fill or to the stroke).
        Btw, CorelDRAW X7 at least had two clickable color buttons for the Fill and for the Stroke in the lower right corner of the window. Did they change that in more recent releases?
        You can dock the Color panel horizontally if you want (drag it by the tab with the name), but it will still show the Fill and Stroke buttons, because they are needed:
        P 2 Replies Last reply Reply Quote 1
        • P Offline
          Petar_MK @b77
          @b77 said in Dealing with colors:
          Btw, CorelDRAW X7 at least has two clickable color buttons for the Fill and for the Stroke in the lower right corner of the window. Did they change that in more recent releases?
          I don't know. I don't use CorelDRAW for a long time and when I used it I never thought about fill and outline icons -- just left and right click with the mouse.
          • P Offline
            Petar_MK @b77
            Of course you have to define the color first with the sliders and then you can choose whether you want to save it to swatches or left/right clcik on the icon to apply it.
              b77 @Petar_MK
              @Petar_MK When in CorelDRAW and you needed a custom color you double-clicked the Fill or Stroke buttons to open a modal window where you could adjust the sliders.
              So I think VectorStyler's approach is faster in this regard.
              There was also this long-press (left- or right-click) on a color swatch that popped a 10x10 matrix with alternative colors close to the initial one.
              Still, adjusting a color with sliders is a must, and Fill and Stroke buttons are needed along with it. Unless there is a better alternative? If there is, explain it step-by-step.
              But if part of what you suggest is a consistent rule (left-click always assigns a color swatch to Fill, right-click always assigns a color swatch to stroke), I definitely agree with that. 👍
              • P Offline
                Petar_MK
                When in CorelDRAW and you needed a custom color you clicked the Fill or Stroke buttons to open a modal window where you could adjust the sliders.
                I can't remember any program where you have to click on fill or outline icon to adjust the color. You move only sliders to define the color which can be used for fill or outline, or click on a color icon in swathes palette to open a dialog box to redefine it.
                  b77 @Petar_MK
                  @Petar_MK Please write the steps — how would assigning a custom color to the fill then to the stroke of an object work, faster than the current method and without leaving the user guessing about where the color is assigned.
                  • P Offline
                    Petar_MK
                    Without icons: STEP 1 -- left click -- fill, right click -- outline.
                    With icons: STEP 1 -- select the icon, STEP 2 -- apply the color. Additional step -- if you want to apply the color to the outline and the fill icon is active, you have to select the outline icon first.
                      b77 @Petar_MK
                      @Petar_MK said in Dealing with colors:
                      Sure, but here you're clicking one of the preset color swatches in the color bar, right? If so, yes, I agree with that.
                      But what if I want a custom color — one adjusted with the sliders, not a preset color from the color bar?
                      Is there a better/faster method than the current one, where (not always, but half of the time) you need to click the Fill or Stroke button in the Color panel before adjusting the sliders for that attribute (fill or outline)?
                      That's what I'm asking.
                      • P Offline
                        Petar_MK
                        You left/right click on the icon next to the sliders where you can see what your color definition looks like.
                          b77 @Petar_MK
                          Sorry, I don't get it. So you want a single icon/button to the left of the sliders, not two — one for Fill and one for Stroke? A visual mockup would help.
                          • P Offline
                            Petar_MK @b77
                            Yes.
                              b77 @Petar_MK
                              @Petar_MK OK, but I don't see the advantage — is it just that instead of activating the Stroke attribute with a click on the part that is not under the Fill button, you now have only one button with two states that can be changed with left- and right-click? Or maybe just with left-click always to change between attributes?
                              Or maybe you just consider a button with two states visually better?
                              Again, sorry if I miss something obvious.
                              • P Offline
                                Petar_MK
                                It is not complicated at all.
                                If you left/right click on the (single) icon next to the sliders or left/right click on a color icon in swatches you apply a fill/stroke (outline) color to the object.
                                No attributes at all.
                                As simple as this.
                                  b77 @Petar_MK
                                  @Petar_MK Not saying it's complicated, but I don't see why it is better than the current two overlapping buttons — one for the Fill attribute and the other for the Stroke attribute. Just because one single button has a bigger hit area?
                                  Also: what are the specific disadvantages of the current method? You do know that you can drag the color from the Fill button to the Stroke button to assign the same color to the stroke?
                                    VectorStyler @Petar_MK
                                    @Petar_MK There is always room for improvement, we just need to clarify a bit.
                                    So first, things that already exist:
                                    • left/right click on color wheel to set fill/stroke colors
                                    • left/right click in palette bar (on the margin of the window) also sets fill/stroke colors
                                    • left/right click in palette panel (a.k.a swatches) sets fill/stroke colors
                                    Things that are missing, and could these help ?
                                    • left/right click on an item in Presets or Styles panels. Currently its left double click by default (can be changed to single click in menu). But these are not used that frequently.
                                    • and a bit stretched, but why not: right click+drag the color sliders in the color panel. The color sliders are the only direct color selection, where the fill/stroke knob should be selected first.
                                    If there are other ways to improve color selection, I'm happy to listen 🙂
                                    • P Offline
                                      Petar_MK @VectorStyler
                                      @vectoradmin said in Dealing with colors:
                                      Yes, thats OK. Setting color without selected object, applying color with selected object.
                                      Sorry, but I don't understand what you mean with these bullets.
                                      Those two knobs (fill/stroke icons) should be replaced with only one knob/icon that can be left/right click to set/apply the color to fill/stroke.
                                        @Petar_MK The second set of bullets are possible ideas for improvement.
                                        The above fill/stroke knob is almost universal by now, so this would be hard to change (from usability point of view).
                                        Do you mean, to have the color selected first with the slider, and then click on an icon to apply as fill and another icon to apply as stroke color?
                                          I was thinking the same thing - this is universal and understood across the board.
                                          I am curous however what this single knob would look like. Would you do a quick sketch of your vision for it @Petar_MK ?
                                          • P Offline
                                            Petar_MK
                                            OK. Just leave it as it is. I can't explain it better. English is not my mother tongue.
