    Is Hyphenation working?
    10 Posts 2 Posters 1.2k Views 2 Watching
      marce
      Hi. Im trying to make hyphenation working. I started with spanish, but no luck. I read in the forum that it was not working for other languages at some time, so im trying to make it work with English US. But i cant make it to work. I selected the English language. An then i went to the paragraph hyphenation settings. Im not sure what settings i must change from the defaults to makes something. I changed before, after, lenght, but no change.
      Could you gave me some default good values for Hyphenation paragraph settings?
      Memory 48gb ddr4
      NVMe CT100p 1TB
        VectorStyler @marce
        @marce Is this on Windows or MacOS?
          marce @VectorStyler
          @VectorStyler Hi, is windows. Any other detail?
          Memory 48gb ddr4
          NVMe CT100p 1TB
            VectorStyler @marce
            @marce I opened a bug on this and will test it on Windows.
              VectorStyler @marce
              @marce I the Character Options -> Typography section, what language is selected in the "Hyphenation" field?
                VectorStyler @marce
                @marce It seems that the default install does not include hyphenation dictionaries for other than English. I will find a solution for this ASAP.
                  marce
                  Hi VectorStyler, sorry i dont know your real name. Here is what i got: Following your tip about Typography section, i change Default to English, and Hyphenation start to work. So, English is OK.
                  But when i selected Spanish in Text>Hyphenations>Language, and then i go to Text>Character Options>Typography>Hyphenation you dont have any other language than "default" and "English". You can see this in the screenshot:
                  I remember when working with the old Pageplus to have a similar problem. They got the non-english hyphenation dictionaries from Libre Office, and it solved the problem. The libreoffice hyphenation dics are standard.
                  The files used for hyphenation in libreoffice are called hyph_es.dic, and if i correctly remember, are free for anyone to use, and available somewhere.
                  Memory 48gb ddr4
                  NVMe CT100p 1TB
                    VectorStyler @marce
                    @marce The next build will contain these dictionaries (next week)
                      marce @VectorStyler
                      @VectorStyler Thanks, great! I see good potential in Vectorstyler layout capabilities. Maybe is not intended to that, or focused to that, but great to have them working properly.
                      Memory 48gb ddr4
                      NVMe CT100p 1TB
                        marce @marce
                        @marce Hyphenation appear to be working fine right now! Thanks a lot!
                        Memory 48gb ddr4
                        NVMe CT100p 1TB
