    Is there a way to align node handles? (one to another)
    6 Posts 3 Posters 57 Views 2 Watching
    • debraspicherD Offline
      debraspicher
      So I have this node and I'd like to "flatten" it so that the right side handle is in line with the other. Is this possible?
      32GB RAM @ 6000MHz
        Boldline @debraspicher
        @debraspicher Have you tried holding down the shift key when you drag the node handle on the right side to match the left side?
          debraspicher @Boldline
          @Boldline Yes, that's usually what I try first. It moves the right handle in fixed directions (0dg, 45dg, etc)
          32GB RAM @ 6000MHz
            VectorStyler @debraspicher
            @debraspicher Select the other control point and use the "smooth node" command (context panel second node type button)
              debraspicher @VectorStyler
              @VectorStyler That worked! I had tried that before but I guess I was hitting the wrong thing someplace
              For anyone else who needs this:
              alt text
              32GB RAM @ 6000MHz
              VectorStylerV 1 Reply Last reply Reply Quote 5
                @debraspicher The only problem is that it should change the selected node position, not the opposite one. Il will fix this.
