Copy paste between VS and other applications
I’m using VS and Affinity together and often copy vector elements from Affinity into VS to make adjustments.
When I paste them back from VS into Affinity, the vectors come in at a smaller size than the originals. I then have to manually reposition and scale them to match their original placement.
I’ve tested this with documents set to the same pixel dimensions in both applications and tried copying objects from VS as both SVG and PDF.
However, I haven’t been able to preserve the original size. (Maintaining position is even more difficult, as pasted elements are centered by default.)
I’ve attached sample documents from both applications for reference.
958f23f3-57dd-4887-a129-30707f342034-VS Affinity copy paste.zip VS Affinity copy paste.zip -
@EricP I added this to the backlog as a bug
