    Right-click to copy or paste in the panel text field does not work
    12 Posts 3 Posters 74 Views 2 Watching
    • W Online
      William Kansepa
      It's intuitive to copy or paste values in the panel text fields, but this method doesn't work in VS.
      Refer to example panel image attached.
      Could you please look into that?
        VectorStyler @William Kansepa
        @William-Kansepa I will try to add this
        • W Online
          William Kansepa
          @VectorStyler thank you for update 1.3.020!
          However, this issue is still not resolved...
            @William-Kansepa It might be that only works on the mac, I will open a bug for this.
              @William-Kansepa said in Right-click to copy or paste in the panel text field does not work:
              I tested this on windows, and when right clicking the field, the number is copied.
              • W Online
                William Kansepa @VectorStyler
                @VectorStyler said in Right-click to copy or paste in the panel text field does not work:
                Here it's still a challenge for me... Maybe there's a setting which I am missing?
                Anyone else experiencing this?
                  @William-Kansepa No settings is needed.
                  In the number field, is there anything selected when you right click?
                  (if nothing is selected, it should copy the whole text)
                    @William-Kansepa
                    Could also be a mouse / input device type issue.
                    What kind of mouse you use for this?
                    • W Online
                      @William-Kansepa
                      I am using a simple HP mouse.
                      I am not facing this kind of challenge in other software...
                      • L Offline
                        Li Xiao @William Kansepa
                        @William-Kansepa I tried it on two different PCs, and it works fine on both.
                        • W Online
                          William Kansepa @Li Xiao
                          @Li-Xiao said in Right-click to copy or paste in the panel text field does not work:
                          @Li-Xiao, Thank you for your response. I think I will have to try another mouse and hopefully I will achieve the desired result.
                          • L Offline
                            @William-Kansepa You're welcome! Could it be a settings issue? A while back, importing AI generated images made VS crash on two Win PCs, but Mac was totally fine. It went back to normal after I reset it to default settings.
