Auto-Sizing for Text Frames based on Text Content
I have a feature request to improve the Text Frame workflow.
Currently, our standard Text Tools already handle horizontal auto-expansion naturally as we type. However, I would love to see this "Auto-Sizing" (Auto-Fit) capability extended to Text Frames as well, allowing the frame boundaries to expand or shrink dynamically based on the text volume:
Auto-Grow Vertically: The frame height expands downward as more lines are added. Auto-Grow Horizontally: The frame width expands to the right to fit the text, just like the standard Text Tool does, but while maintaining the properties of a Text Frame (such as text wrapping, padding, and column settings).Since I am a designer and not a programmer, I don’t know how the layout engine will calculate these frame boundary changes, but it would be incredibly powerful for creating dynamic labels, badges, and flexible template layouts.
Could this be considered for the features backlog alongside the other layout markers?
Best regards,
@861475_VctSt I will add this to the features backlog
@861475_VctSt
If you double click on the bottom or right resizing knob with the transform tool, then the text frame should be resized to fit the text.
But not automatic resizing yet, while editing. -
Thank you for the great tip!
I immediately tested the double-click behavior on the frame handles. The double-click on the bottom-center handle works perfectly to fit the frame vertically. However, double-clicking the bottom-right or Right handles makes the frame lose control.
Is there any setting in the current Preferences to control or stabilize this behavior? For now, I am more than happy to rely on the bottom-handle shortcut.
As a non-programmer user, may I suggest a priority for the implementation? I feel that vertical auto-growth is the most critical feature. Since VectorStyler already handles horizontal expansion beautifully with the standard Text Tool, horizontal fitting for Text Frames might be less urgent. Even in QuarkXPress history, vertical fitting was implemented first, and horizontal fit came much later.
Thank you again for your incredible responsiveness!
Best regards,
@861475_VctSt Send me an example file where the bottom-right handle clicking has issues
I sent the data by email.
Sorry for the confusion. By "losing control," I meant that the frame resizes in an unintended way.
Here is what happens:
When I double-click the bottom-right handle, it fits both horizontally and vertically at the same time, changing the text frame size completely.For example, if I want to fit the frame vertically while maintaining the exact width of 100mm, only the bottom-center handle works correctly as expected. Double-clicking any other handle alters the width, which is not the desired result.
This is by design:
bottom handle: resizes vertically to fit (keeps the width)
right handle: resizes horizontally to fit (keeps the height)
bottom-right handle: resizes proportionally changing both width and height. -
Thank you for clarifying the default behaviors.
Just to confirm: is it correct to assume that there are currently no options in the Preferences to change or customize these default handle behaviors?
Also, regarding the right handle:
right handle: resizes horizontally to fit (keeps the height)I’m having a little trouble imagining how it actually fits horizontally while "keeping the height" in a text frame context.
For now, I am more than happy to rely on the bottom-center handle to maintain my width.
Best regards,
@861475_VctSt said in Auto-Sizing for Text Frames based on Text Content:
No option to customize these.
Resizes the frame horizontally, so that the text will fill the frame
I now fully understand the current behavior. Even with the current mouse operations, I find the double-click actions to be highly useful for my workflow.
As for the future backlog implementation, please don't rush to do everything at once. I think it would be perfectly fine to roll out vertical fit first, and then horizontal fit down the road when the time is right.
Thank you so much for the helpful tips and for listening to my requests.
Best regards,
